Author Topic: 396 Big block engine photo request  (Read 7753 times)
sul423
« on: May 01, 2014, 02:41:28 PM »
I am looking for photo of 396 big block engine which came with 1969 Camaro SS that showing the original condition.
I need photo similar to the that photo of 1967 Camaro Z28 302 cubic-inch engine.
Mark
Re: 396 Big block engine photo request
« Reply #1 on: May 01, 2014, 05:43:53 PM »
No 67 Z28 engine left the factory looking like that.  Thats got way to much spit an polish on it, Manifolds were already on it when it was painted, so those would have overspray on them.  Everything on that engine is just a little to shiny.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #2 on: May 02, 2014, 10:05:56 AM »
As Mark mentioned the 67 Z/28 engine did not leave like that. It's a cool picture but obviously not one to use for any type of restoration. One alt. bracket not installed, ground stud not installed in water pump, no lift hooks on manifold, no paint on by-pass water pump/manifold hose & clamps, etc.. If you do a search there have been some threads discussing engine paint techniques on big blocks along with pictures. Here is an example-  http://www.camaros.org/forum/index.php?topic=11414.0;all
sul423
« Reply #3 on: May 16, 2014, 08:42:23 AM »
Thanks a lot.
« Reply #4 on: May 21, 2014, 04:27:19 PM »
Here are some photos of a L35 I recently painted, please note that I was not able to find the color that this engine was painted originally so I mixed my own and then used a Paache VLS airbrush to spray the engine.
NoYenko
« Reply #5 on: May 23, 2014, 12:09:42 PM »
James, looks great, I like the slightly duller paint finish. I think you nailed it. After run in it will look even better. I'd like to see more pictures of this car, its just after my build date. George
sul423
« Reply #6 on: June 21, 2014, 05:21:28 PM »
Thank you James
