Author Topic: Bad Luck is Better Than No Luck; Right?  (Read 52806 times)
Re: Bad Luck is Better Than No Luck; Right?
« Reply #45 on: June 16, 2014, 04:44:42 PM »
those small compressors can be depressing with how slow they go, and having to wait on them. Good thing is they go so slow getting the air pressure back up it really forces  you to take your time, and less mistakes. Trying to see the cup half full for ya
« Reply #46 on: July 27, 2014, 10:45:44 PM »
For anyone building an engine or working on some heads; I would suggest you look into Cerakote coatings.  So far this stuff is amazing and incredibly easy to apply and I can see the durability in these coatings.
« Reply #47 on: December 31, 2014, 09:41:12 PM »
Its been a little over 8 months since I have heard this engine run.  Yesterday I began putting it on the run stand and ran into problem after problem.  Today the fruits of my labor finally paid off.  Still plenty to do.  Engine needs to be painted and laid into the engine bay.  More to come in the next few weeks.
The video of the sweetness.
« Reply #48 on: December 31, 2014, 10:10:38 PM »
Yea! Congrats! Happy New year! patience is rewarded. Glad for you my friend.
HawkX66
« Reply #49 on: January 01, 2015, 03:27:16 PM »
Congrats Darrell! Sounds great! Love that stand. Did you build it from scratch or was it a kit? What kind of advantages do get from the coated pistons? I love Cerakote from my firearms, but I never thought to do any engine coatings with it.
« Last Edit: January 01, 2015, 03:51:13 PM by SgtHawkUSMC »
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
« Reply #50 on: January 01, 2015, 07:19:02 PM »
Thanks guys.  The engine stand was a kit and I borrowed it from a fellow local car guy.  The micro slick is used on the piston skirts as well as main, rod & cam bearings.  Like many aftermarket pistons that come with the coated skirts this is used as a dry lubricate for wear.  The piston coat is used to aid in thermal properties.  Allowing the reduction in hot spots on pistons and combustion chambers by allowing to dissipate the heat evenly over the surface.  Not often used in street N/A engines (piston coat) but helps with forced induction applications.
« Reply #51 on: January 01, 2015, 07:21:32 PM »
So your planning on dropping it in the S-10 for the break in period right???    :D
(good job Darrell)
« Reply #52 on: January 01, 2015, 07:43:06 PM »
Yep a 396 bbc s10.   ;)
« Reply #53 on: January 03, 2015, 10:11:28 PM »
I do suggest using a slightly larger gas tank -
Regards
« Reply #54 on: January 19, 2015, 01:23:23 AM »
Baby steps.  Almost there.
6667ss138
« Reply #55 on: January 19, 2015, 01:31:41 AM »
Wow, that looks great Darrell!
« Reply #56 on: January 19, 2015, 01:57:30 AM »
X2...I expect nothing less from you DW
BillOhio
    • photobucket
« Reply #57 on: January 19, 2015, 04:21:33 AM »
Looks and sounds good!
1968 RS 327 4 speed
« Reply #58 on: January 19, 2015, 12:06:04 PM »
looking good
« Reply #59 on: January 19, 2015, 01:01:53 PM »
Thanks guys.  I hope to hear it run in the car by this coming weekend.  I hope.  Once I finish it Ill post a video of the whole car after I do a deeeeeeep clean. ;D
