Author Topic: Amazing 69 Z/28 Survivor  (Read 367594 times)
Re: Amazing 69 Z/28 Survivor
« Reply #225 on: December 15, 2016, 09:39:51 PM »
Have you looked at the PCV to see if its the Spun one? looks by pic that its not??
Rich, yes it still has the old spun valve which was checked during Vintage Certification.
« Reply #226 on: December 27, 2016, 02:55:33 AM »
I thought this was interesting. On spoiler cars, I thought the holes for Camaro trunk emblems were drilled in both the lower and upper positions. There is no sign that the lower holes were ever drilled on this lid. Also, there are no acorn-style nuts along the back edge spoiler studs.
FWIW there is a research topic on the piercings on the decklid... this is the best discussion on the subject without rival.
http://www.camaros.org/forum/index.php?topic=3752.0
« Reply #227 on: January 12, 2017, 11:43:22 AM »
Original battery tray and note the tab where the battery hold down clamp attaches. I've not noted a NOS service replacement battery tray yet with the tab but have pictures of several survivors that have the tab.
« Reply #228 on: January 20, 2017, 04:25:36 AM »
Some detailed hardware pictures.
"RSC" marked distributor hold down bolt
Both lift brkt shouldered "M" marked bolts
Anchor marked coil brkt screws with star washer.
Spark plug looms attached to valve covers are natural with rubber type coating.
« Reply #229 on: January 20, 2017, 02:40:37 PM »
Chick,  those are very nice and detailed photos which will help many here... :)
6667ss138
« Reply #230 on: January 20, 2017, 11:28:51 PM »
Thanks, Chick!
« Reply #231 on: July 21, 2017, 01:52:53 AM »
Some say the a-arm shims were zinc from the factory but what I've noted seems to indicate they were natural with no coating. Note on Skip's A-arm how well preserved the zinc nut is, the painted A-arm assembly, and how rusty the original shims look. No remnants of zinc IMHO.
Now to the lower hood release and how it is attached with four 3846202 captured washer screws.
BillOhio
    • photobucket
« Reply #232 on: July 21, 2017, 05:58:12 PM »
It appears Skips distributor hold down is painted?
1968 RS 327 4 speed
« Reply #233 on: July 22, 2017, 03:09:32 AM »
Yes Bill, and a few intake bolts had remnants of silver paint on as they were not zinc as seen in one picture.
Charley
« Reply #234 on: July 22, 2017, 04:14:20 AM »
My 1100 mile 70 Z28 also had it's dist hold down and other brackets painted silver and others were brush painted orange.
« Reply #235 on: July 23, 2017, 11:57:29 AM »
Reply #231
Like most of everything else, my shims were entombed in undercoating and/or paint. No corrosion. The surfaces which mated next to each other bore no sign of zinc, from what I could observe. Nothing shiny. And I had my reading specs on 8) They received a low pressure bead blast and a coating of Sharkhide. You can see part of the shim tab upper left corner.
« Reply #236 on: January 29, 2018, 03:52:38 AM »
So I was reviewing Skips car, and noticed a couple of things. Looks like the original owner installed some aftermarket rear speakers. Was this a factory AM/FM car?
Also in relation to the radio. Shouldn't there be the rosewood trim pieces on the radio face behind the volume knob and tuning knob?
« Reply #237 on: September 16, 2022, 03:22:37 PM »
I took this picture recently reviewing and confirming that the screw and bottom section of spark plug 2 piece heat shield (drivers side) that bolts to block was installed prior to paint at Flint and bolt's captured washer was in fact a star type locking washer.
« Reply #238 on: March 23, 2023, 06:38:45 PM »
All four center caps have a prominent indent from inner portion to face. The inside of caps have double poles or columns where screw attaches. Bottom of inside cap is different from earlier caps smoother bottom. All cap inside bottoms stamped #3925805 and 5525504.
cap 1969 step2
cap 1969 step
cap 1969 09D
