Author Topic: Correct locaton of proportionong valve on sub frame  (Read 28870 times)
melav8r
Re: Correct locaton of proportionong valve on sub frame
« Reply #15 on: June 09, 2008, 01:21:28 PM »
I can't explain why Chevy named them the way they did, but functionally, the one on the frame is a true proportioning valve (and its function was later incorporated into the "combination valve" that combined proportioning, front metering, distribution, and differential pressure switch functions in the mid-70's). The round one under the master cylinder has no proportioning function - it just remains closed until its inlet sees 30-40 psi, then it opens and allows fluid pressure to the front discs.
The function of the round metering valve (or "hold-off" valve) is to allow the rear system to see 30-40 psi (which moves the rear drum shoes out into contact with the drums) before the front discs see any pressure, to avoid disconcerting "front brakes first" on pedal application, which causes "nose-dive" at low speed. The metering valve on my '69 Z/28 is stuck open (needs a rebuild), and at low speed light brake application the car nose-dives and feels like it'll stand straight up on its nose when you step on the brakes. Gotta rebuild it this winter if I can find the correct kit with ALL the seals.
With that said I think my hold off valve (round valve) may not be opening soon enough since I tend to get premature rear brake lock up during panic stops. Because of this I took apart the subframe mounted proportioning valve and cleaned out what appeared to be hardened or glazed brake fluid gunk but the back wheels still tend to lock up during hard braking. Do you think tearing into the hold off valve will resolve my issue? how do you test the hold off valve for proper function?
L78 steve
« Reply #16 on: June 09, 2008, 05:38:21 PM »
As far as a supplier for the frame valve parts I had no luck at finding one .So I purchased a new re-pop from Inline tube and stole the parts out of it to rebuild mine .A little expensive but it worked .I got to keep my correctly dated valve .
69 Z/28 Dover White. SOLD
Buddy
« Reply #17 on: June 10, 2008, 06:12:44 PM »
Quote
Hey, thanx JohnZ, you just fixed my 66 Caprice 396...Woo Hoo  :)
« Reply #18 on: June 15, 2008, 06:23:09 AM »
Here is an disassy view of the valve from the subframe:
no69x-44
« Reply #19 on: August 14, 2008, 07:57:59 PM »
Ok, this is not rockets science we are dealing with here ... But I have been having nothing but problems with my brakes now that I'm near the end of my rebuild. I don't want to bore you all with all the details of my woes ... But will just start off where I am now.
What I have is all brand new or newly rebuilt as follows:
Master Cylinder (309)
Proportioning valve
Disc Calipers
Pads
All Lines and Hoses
Power Booster
Etc.
So basically the entire brake system is all spanking new. There are no leaks at all and the brakes - front and rear bleed with a smooth clear stream (over and over again) and looks fine - no air. When the brake pedal is hit, the rear brakes work perfectly. No issues. They grab tight and hold.
Now the %^&#&% Front disc is another issue! They don't seem to grab at all. But yet, if I pump the brake pedal 5 or 6 times, the grab a little more with each pump, and then hold tight. Once I let off the brake, the it's the same thing again. 5-6 pumps before the front hold tight. Again the rear are working as designed.
I'm stumped and at wit's end on this. This should be a pretty simple thing and it is beating the crap out of me. I'm about ready to swap out the Master ... Again!
But after reading through this thread (good stuff), I am now thinking this just might a proportioning valve issue - even though I all ready replaced my original one (the round one under the master cylinder).  Any and all help/advice would be most appreciated.
--Rob
'72 SS Nova - Gone
'68 Chevelle - Gone
'67 Impala - Gone
'65 Belair - Gone
'00 Corvette - Still got it
'69 Camaro - Keeper
« Reply #20 on: August 14, 2008, 08:58:29 PM »
 This should be in the Maintenance section. But if the piston is not returning in the master it will not function properly. And the round metering valve still may be at fault.   Once again-- new does not mean good.
« Reply #21 on: August 14, 2008, 09:07:50 PM »
 You may also have a check valve proplem with the master.
http://www.camaros.org/forum/index.php?action=search2
« Reply #22 on: August 15, 2008, 07:23:17 PM »
The 69 Chassis service manual says that the valve was only used on Camaro's with the 8-7/8 ring gear and only after mid year...
« Reply #23 on: December 06, 2008, 10:16:16 PM »
Update w/ Disassy photos.
I ended up just taking it apart and cleaning it up w/ brake fluid and carfully re-assembling.
Hope this is helpful.
CVKUEBER
« Reply #24 on: December 07, 2008, 06:09:56 PM »
Proportioning valve
Disc Calipers
Pads
All Lines and Hoses
Power Booster
Etc.
Compare old master cylinder with new, Check the depth of the hole of the master cylinder piston that the pedal pushrod fits into. Theres a chance that the piston is not being forced in far enough. I ran into this problem helping Ken Boje with the Gibb z/28
tom
    • Discount Internet Services
« Reply #25 on: December 08, 2008, 01:34:37 AM »
Are the calipers installed corectly? I recall reading that they will install on the wrong side, but if that is done they do not bleed correctly because of the position of the bleeder leaves air in the caliper.
69 X11 Z21 L14 glide
o
