Author Topic: rain drip bright molding  (Read 6699 times)
« on: April 07, 2014, 07:20:32 PM »
Are the aftermarket accurate and good? I have my original, but they are flawed. this is for 69 specifically, but I think all three years are the same.
Re: rain drip bright molding
« Reply #1 on: April 07, 2014, 07:29:51 PM »
All 3 years are the same.  You can polish them out if you so desired.  It is a lot easier to polish them if they are on a car before it is painted.  If there are dings or scratches in them then those will need to be taken care of before polishing obviously.  No info on repos.  I have polished all my original windshield and back glass trim and plan on doing the drip rail moldings at a later date.
68ashgoldRS/SS
« Reply #2 on: April 07, 2014, 09:49:52 PM »
Hi Darrell,  I'm guessing those are stainless as well? Is there a point where you can polish them to a substrate level and discolor them?  I'm haveing an issue where it appears that I'm down a little too far, and getting a copper tint.... They are factory originals....
Ed Denney from South Jordan Utah
1968 Camaro RS/SS -Restored
1959 Chevrolet Corvette Restomod-Project in progress
1956 Dodge D100 Pickup -Project
1936 US Soldier, Dad -Best Friend
« Reply #3 on: April 07, 2014, 11:14:45 PM »
Yes you can "burn" the stainless.  I have gotten several pieces extremely hot and haven't burned a piece.  What cutting compound are you using?  Stainless isn't like chrome.  I have even sanded areas after working dents out and going from 80-1200 grit then on to polishing
« Reply #4 on: April 07, 2014, 11:22:27 PM »
Here is some good reading on polishing stainless
http://www.caswellplating.com/buffman.htm
« Reply #5 on: April 07, 2014, 11:44:04 PM »
You may have sanded or buffed through the flash chrome.
I have a car that was shipped to me for assembly which was supplied with repro drip rail moldings from D&R. From what I recall they were not as bad as anticipated. When I pull them out again I'll double check. LH NOS molding can be purchased at GM Parts Direct.
« Last Edit: April 08, 2014, 12:27:58 AM by Sauron327 »
« Reply #6 on: April 08, 2014, 01:01:35 AM »
Didn't realize these were flash chromed.  If that's the case you could always have them hard chromed again.  Here are some pieces I polished this past weekend.
68ashgoldRS/SS
« Reply #7 on: April 08, 2014, 04:35:28 PM »
Ok, that would exlain it.... a little over enthusiatic on my buffing! I'm in the same boat as ko-lek-tor, with rechroming or buying a replacement...
Darrell, those look great!!! And thanks for the link!
