Author Topic: Wiring lume for the trunk of a 68 rs  (Read 10715 times)
Matt f
« on: April 02, 2014, 10:17:43 AM »
Hey Chaps
The wiring lume looks a bit tattered so I want to change the section that feeds the rear of my car (ie.lights) but following
the lume thru the trunk into the cabin it doesn't join anywhere. Does this mean that I would have to replace
the complete wiring lume in the car from front to back
Hope not
68rs327conv
    • The build
Re: Wiring lume for the trunk of a 68 rs
« Reply #1 on: April 02, 2014, 11:22:18 AM »
Mine is a 68 convertible and the rear harness runs from the front all the way to the rear.  The connector as I recall is behind the drivers kick panel.
68 RS Conv 327/210hp, Powerglide Factory AC
gkweber3
« Reply #2 on: April 03, 2014, 11:00:27 PM »
Yup, 68rs327conv is right, the rear harness connects up at the dash. You have two choices - as there are only a couple of wires that go to the rear, you can splice it behind the rear seat/quarter windo area, you can re-tape the original wiring if you are only looking for cosmetic upgrade, or you can take everything apart and plug the new harness in at the front........sorry.
« Reply #3 on: April 04, 2014, 01:54:06 PM »
Hey Chaps
Hope not
When you state the wiring lume looks a little tattered do you mean the plastic sheath that encompasses the wiring? They usually become brittle and become a little ugly. If that is the root issue you might want to find a donor piece of sheath and replace only from the back seat back. If you do this take measurements to replace the tab holders in the exact location, use the correct type tape to tape them on, and take notice to how they were taped on to replicate. On this page I have a couple pics of our 68 wiring harness.
http://www.camaros.net/forums/showthread.php?t=182584&page=54
68ashgoldRS/SS
« Reply #4 on: April 04, 2014, 09:04:33 PM »
Yes, same on my 68 RS/SS... front to back, with the connector behind the drivers side kick panel...
Ed Denney from South Jordan Utah
1968 Camaro RS/SS -Restored
1959 Chevrolet Corvette Restomod-Project in progress
1956 Dodge D100 Pickup -Project
1936 US Soldier, Dad -Best Friend
Matt f
« Reply #5 on: April 22, 2014, 08:17:17 AM »
Hey fellas
Just about to change the wiring harness in my 68 and noticed that there is a socket on top of the wheel arch.  I'm assuming this is for
the under boot lighting if it was ordered or are the harnesses different for each?
Matt
« Reply #6 on: April 23, 2014, 02:26:44 AM »
Hey fellas
Matt
What brand wiring harness did you purchase? Are you referring to the wheel arch in the trunk Matt?
Matt f
« Reply #7 on: April 24, 2014, 08:31:50 AM »
Im guessing by the condition its the original one, not sure what brand.  Yeah its the wheel arch in the trunk.
VINCE Z28
« Reply #8 on: April 24, 2014, 06:25:52 PM »
Chick do you see any difference in original vs American auto wirings ( Factory fit harness ) ?
