Author Topic: ebay los angles 302 9L524802  (Read 25583 times)
« on: March 20, 2014, 05:36:04 PM »
Here is an auction for a 302 Los Angles block. I hope the owner of the car sees this ad.\
Vin stamp looks to be : 19L524802
stamp on block: V0211DZ
 As always buyer beware and do your homework prior to purchase. Good luck!
http://www.ebay.com/itm/1969-Camaro-Z28-DZ-302-/321356167044?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4ad251f784&vxp=mtr
seller : 64 Saddletan
Re: ebay los angles 302 9L524802
« Reply #1 on: March 20, 2014, 06:38:35 PM »
Actually, the seller id is 64saddletan   ;)
Block casting number:  3956618
Block casting date:  A 31 9
Seller location:  North Reading, MA
« Reply #2 on: March 20, 2014, 07:10:34 PM »
Thanks for adding the block casting numbers, the correct eBay user I'd.
Kelley W King
« Reply #3 on: March 20, 2014, 08:01:27 PM »
you can tell he is an engine man. Hydrolic lifters
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #4 on: March 20, 2014, 08:04:24 PM »
Well maybe someone decided to go to a hydraulic roller. I put a 327 with a high lift hydraulic roller cam in mine and have been very happy thus far.
« Reply #5 on: March 26, 2014, 08:16:10 PM »
No sale 3-26-14...
Reserve not met = $4000.00
« Reply #6 on: March 28, 2014, 02:22:45 AM »
I put a hydrolic (sic) roller in miy Z in '75 - an Erson HiFlow IIH, car ran like the proverbial scalded dog (12.5:1's didn't hurt). I look back on it now and wonder why I did it, but it made sense at the time (I got tired of setting rockers all the time).
Regards -
« Reply #7 on: March 28, 2014, 02:45:02 AM »
Well I recently just finished with the finishing touches on my C/10 set the rockers on mine and tightened down the allen's on it and hopefully I won't have to mess with them for a while now. Runs great with the 4 speed, but I have a bad vibration around 50mph, so I have to check the pinion angle and check the angle. it is deffinetly a mph issue, so maybe the clutch (which i need to adjust).
69 Zee
LOST 19L524802 V0211DZ if it's real !
« Reply #8 on: September 07, 2014, 02:09:35 AM »
Darrell
Re: LOST 19L524802 V0211DZ if it's real !
« Reply #9 on: September 07, 2014, 02:13:31 AM »
Last time (and only time) I had seen a yellow small block was in a '32 Roadster.
« Reply #10 on: September 07, 2014, 02:19:46 AM »
Well..  in 1957, Chevrolet actually painted some 265 ci small blocks yellow (actually chartreuse, which is a greenish yellow)...
69 Zee
« Reply #11 on: September 07, 2014, 02:33:35 AM »
Must of been in some deck out engine in which the car was the same yellow.  Looks like a chrome water pump up front.
Darrell
« Reply #13 on: September 10, 2014, 01:16:48 AM »
No sale 9-9-14...
