Author Topic: My 69 SS/RS Project started  (Read 76826 times)
sul423
Re: My 69 SS/RS Project started
« Reply #75 on: May 16, 2014, 08:30:49 AM »
You displayed a new automatic transmission that I assume you will be using, correct? If not already planned for you will need a different cross-member as the one in your picture is for a manual transmission.
Thank you for notifying me about it. So get one.
sul423
« Reply #76 on: May 16, 2014, 08:32:19 AM »
Good story and write up Fahad and welcome, amazing where the famous 69 camaro can show up I'd of never thought Saudi Arabia- wow! its also kind of amazing what the previous owner did to this car. keep us updated
Thanks and I will do.
sul423
« Reply #77 on: June 23, 2014, 04:59:16 PM »
Here some of the front end preparation
sul423
« Reply #78 on: June 24, 2014, 05:28:42 PM »
Here some pictures of front disc brake conversion kit.
Unfortunately the caliper is installed in opposite way as per the following article from SUPER CHEVY mag.
http://www.superchevy.com/how-to/1404-disc-brake-conversion/viewall.html
The position of the caliper will be corrected soon.
« Reply #79 on: June 24, 2014, 08:06:07 PM »
That looks very clean. It looks like you are building it to be a driver right?
sul423
« Reply #80 on: June 25, 2014, 01:58:34 AM »
Yeah right.
« Reply #81 on: June 25, 2014, 11:35:57 AM »
Looks like you are coming along on your project :) I'm removing my sub frame and detailing this fall.
Did you end up going with the 496 rotating assembly for your big block ?
sul423
« Reply #82 on: June 28, 2014, 11:43:07 AM »
Thank you janobyte and best of luck for your restoration project.
Currently I am keeping my engine as it is with planning for 496 stroker.
sul423
« Reply #83 on: June 28, 2014, 12:02:37 PM »
Here is the rebuild of the power steering box
sul423
« Reply #84 on: July 04, 2014, 06:06:15 AM »
Some of disassembly process for my 69 Camaro
ggtsvnv
« Reply #85 on: July 22, 2014, 04:27:13 PM »
Seems i seen you do a build on a chevy truck a while back.  If your the same person then you did a great job on that truck and i have no doubt that your camaro will come out great. Keep up the great work!
