Author Topic: My 69 SS/RS Project started  (Read 76838 times)
Re: My 69 SS/RS Project started
« Reply #60 on: March 24, 2014, 12:47:44 AM »
No VIN tag - I'd make sure to ask the prior owner if he still has the 69 dash with the VIN. Very important part (the VIN).
Not sure where you would get the 69 metal dash parts except from a parts car.
Drum brakes? I don't think this originally was an SS then. Maybe a LM1?
mickeystoys69RSSS
« Reply #61 on: March 26, 2014, 11:50:55 PM »
Tail light lenses are not RS and I do not see the cut outs for the back up lights in the rear pan so I don't think it is an RS either.
« Reply #62 on: March 27, 2014, 12:05:06 AM »
If you read his earlier post and pic, he says the RS tailights got swapped out at one point, and you can see in the pic he posted that the back up lights got filled in as well.
« Reply #63 on: March 27, 2014, 12:08:27 AM »
I believe a pic was posted that showed reverse light holes filled in, in an earlier post in thread. I think Fahad should be checking that hidden VIN and making sure his car was not sent overseas because there is a problem with its history.
sul423
« Reply #64 on: March 27, 2014, 08:16:47 PM »
Some stuff are going to the sand blasting.
« Reply #65 on: March 27, 2014, 08:44:02 PM »
I would hold off on sand blasting the steering box, you don't want small particles getting in through the seals and ruining it. The rest looks good though
sul423
« Reply #66 on: March 27, 2014, 08:47:58 PM »
By the way I would buy repair kit for the steering box.
Many thanks for your observation.
jacmac
« Reply #67 on: March 27, 2014, 11:41:07 PM »
jacmac
« Reply #68 on: March 27, 2014, 11:46:19 PM »
Well you have plenty of sand there ;) I have blasted steering boxes before, i use small rubber hoses around the seal areas with lots of tape,seems to work good.That looks like a nice project,good luck! BTW were will you get parts from,& how long do they take to get there??
sul423
« Reply #69 on: March 27, 2014, 11:51:29 PM »
Thanks jacmac.
I am ordering parts from USA and the shipping take around one month.
sul423
« Reply #70 on: March 30, 2014, 08:11:40 PM »
My Camaro parts are back from sand blasting and painted.
« Reply #71 on: March 31, 2014, 02:54:38 AM »
Great start, keep up the good work.
sul423
« Reply #72 on: March 31, 2014, 03:13:14 AM »
Thanks.
« Reply #73 on: April 01, 2014, 11:22:15 AM »
You displayed a new automatic transmission that I assume you will be using, correct? If not already planned for you will need a different cross-member as the one in your picture is for a manual transmission.
zman1969
« Reply #74 on: April 24, 2014, 08:48:45 PM »
Good story and write up Fahad and welcome, amazing where the famous 69 camaro can show up I'd of never thought Saudi Arabia- wow! its also kind of amazing what the previous owner did to this car. keep us updated
Rich
69 RS/Z DZ302 Daytona bumble bee
69 T/A clone LS6/6sp
69 Nova SS 396
