Author Topic: Correct Striping  (Read 28299 times)
JT Z28
Correct Striping
« on: March 10, 2014, 03:42:45 AM »
Hi all,
I am trying to determine the correct color (Striping) for my 69 Z28.
I know the original color (Hugger Orange) but can't if striping white or black?
I believe (correct me if wrong) standard (basic) was white unless requested black or removed.
Thanks for any assistance.
v/r
JT
tom
    • Discount Internet Services
Re: Correct Striping
« Reply #1 on: March 10, 2014, 04:11:08 AM »
Post a good photo of your trim tag. Is or was there a vinyl top? If so what color?
To figure it out for yourself, look here: http://www.camaros.org/numbers.shtml#ExteriorColors:T:1969
69 X11 Z21 L14 glide
o
JT Z28
« Reply #2 on: March 10, 2014, 04:18:19 AM »
Hi Tom,
Mahalo here's what's on trim tag will try to get a good photo but might hard, was painted over so I used paper/pencil and went over it..
ST 69 12437 LOS138497  BDY
TR 712                  72 72 PNT
?OB                      L212
Unable to make out the ? entry....
Kudos' s for your assistance..
JT Z28
« Reply #3 on: March 10, 2014, 04:20:05 AM »
The top isn't vinyl sorry forgot to add
jack92584
« Reply #4 on: March 10, 2014, 06:01:16 AM »
72 72 Stripes would be white
69 Z28 / Hugger Orange /  Deluxe Houndstooth  / M21 / 4:10 Posi / GM of Canada documented
JT Z28
« Reply #5 on: March 10, 2014, 06:15:13 AM »
Mahalo, greatly appreciate you writing/assisting me.
v/r
Jamie
JT Z28
« Reply #6 on: March 10, 2014, 06:25:22 AM »
Would you happen to know what the ?OB would mean; not the ? of course but what this area on tag identifies?
tom
« Reply #7 on: March 10, 2014, 07:08:09 AM »
is the 0 right next to a rivet? I'm thinking 10B = second week of October.
72 72 = hugger orange body & top (no vinyl or vert) = stripes are white.
o
JT Z28
« Reply #8 on: March 10, 2014, 07:16:57 AM »
Yes it's exactly right there, thank u much for taking time to assist me!
asm69
« Reply #9 on: March 10, 2014, 08:11:03 PM »
My 69 z is also a 72 72 with a LOS build. I also think that the build date is 10B. I have the short rear stripes. Their are other threads
regarding that some of the early built z28's followed the assembly manual specifications for the rear stripe layout. Others have commented that
the assembly manual is wrong, but with no supporting evidence.
asm69
JT Z28
« Reply #10 on: March 11, 2014, 05:40:34 AM »
Thank you, yup thats why I wanted to check with folks. From my research I was finding the same document (assembly) manual was incorrect or/and not able to valid the documentation. I was trying to locate the correct tone of stripe as well.  Grateful you took the time to share with me.
« Reply #11 on: March 11, 2014, 02:45:03 PM »
asm69
We've known for many years that the rear stripe illustration in the Chevrolet Assembly Manual (section Z28, sheet B2, View "A", 5.20" dimension) is wrong; Fisher Body didn't use the AIM - they used their own Operation Description sheets ("O.D. Sheets") and Release drawings from GM Styling to create the stencils used in production.
JT Z28
« Reply #12 on: March 11, 2014, 06:53:23 PM »
Than you JohnZ greatly appreciate your sharing. This list is truly a blessing!
« Reply #13 on: March 11, 2014, 07:50:14 PM »
The white stripes would be CODE 50 "Dover White"
I have some pics of an original owner survivor 9B LOS Z28 which has the narrow rear stripes, however I have never seen an original "short stripe" car.
JT Z28
« Reply #14 on: March 12, 2014, 06:00:36 AM »
Wow James, big Mahalo for sharing.  May I get a contact number from you? Would like to share a bit in detail my project.
God Bless
Jamie
