Author Topic: L6 starters  (Read 28563 times)
L6 starters
« on: March 07, 2014, 11:29:31 PM »
I'd like to confirm the starter usage on L6 cars.
So I'm looking for the original starter numbers off of any 67-69 L6 car.
Especially 67 since manual and auto may have used different part #'s.
Pretty sure the 69 L6 starter I have at home is 1108365. It will be a while before I can confirm that....
Thanks!
Re: L6 starters
« Reply #1 on: March 09, 2014, 07:11:06 PM »
Thanks!
X2 Kurt. I can confirm a 1969 6 cylinder laying out in the shed (untouched/unmolested original down to heater hoses and air cleaner filter,which I personally pulled) has its original starter and it is 1108365 also. It also has McKinnon stamped on it as the car was of Canadian build (Buick). Also, there is a real low hour/mileage L6 GM engine (born with) in my 1969 Gleaner K Combine and it, too, has a 1108365 on it.
Re: L6 starters
« Reply #2 on: March 10, 2014, 02:55:57 AM »
But that's not confirming the Camaro application. :)
Sounds like this starter had many 69 L6 applications.
Kurt
Re: L6 starters
« Reply #3 on: March 10, 2014, 05:07:27 PM »
Kurt
You are right. Best I could come up with. The mounting holes are straight across, one short,one long bolt.
Re: L6 starters
« Reply #4 on: March 10, 2014, 05:11:13 PM »
more pics:Middle is solenoid #, alum. front cover.
Re: L6 starters
« Reply #5 on: March 11, 2014, 06:24:45 AM »
Yup, in-line bolts equals the 12 3/4 flywheel.
Thanks!
stovebolt
  • 1968 L6 Sport Coupe
Re: L6 starters
« Reply #6 on: March 19, 2014, 09:38:22 PM »
The starter number on my L6 1968 Sport Coupe is 1108365. The assembly date of the starter is 8C29, the build date of the car is 04A.
Re: L6 starters
« Reply #7 on: March 20, 2014, 03:01:21 AM »
Thanks! That helps alot.
68SixBangerRS
  • Camaro Project from HELL
Re: L6 starters
« Reply #8 on: May 07, 2014, 01:33:35 PM »
My '68 RS with a 230 and 3-speed manual has an 1108365, and the build date is "8A" (the day portion was never stamped...laziness maybe?). The car was built 02D. Thanks for all of the research you have done, Kurt. Are you still in Costa Rica?
Re: L6 starters
« Reply #9 on: May 16, 2014, 09:57:32 PM »
2 solid 68 datapoints. Only question is on early 68 cars, since the part # superceded the 67 part in Oct 67. But that may be just paperwork, not reality.
Still missing any solid 67 L6 data.
Yup, still in CR for a few more weeks.
Thanks!
