Author Topic: Question on exhaust manifold tube support  (Read 12393 times)
1967RS/SS
« on: February 19, 2014, 04:05:09 PM »
I am trying to install D&R’s 2-1/4” exhaust system (non-chambered) and have a question because this kit had no instructions and I have never done this before.
How tight do the extensions fit inside the pipes? Mine seem like I would have to press them in for them to fit inside the pipes.
I am talking about these small extension tubes that support the donut into the exhaust manifold seen here: http://www.heartbeatcitycamaro.com/store/product/21193/Camaro-Exhaust-manifold-tube-SB-1967-1968-1969-1970-1971-1972/
1967 RS/SS L-48
Van Nuys 01C
Joseph
Re: Question on exhaust manifold tube support
« Reply #1 on: February 20, 2014, 04:18:53 PM »
If the parts are made properly, the extensions should drop right in without having to force them.
1967RS/SS
« Reply #2 on: February 20, 2014, 04:22:05 PM »
Ok thanks. It looks like the extensions I have may be too big for the pipes then. Back to the parts store...
1967 RS/SS L-48
Van Nuys 01C
Joseph
tom
    • Discount Internet Services
« Reply #3 on: February 25, 2014, 08:12:09 AM »
Might try putting them in the freezer for a bit before you return them. Might or might not shrink them enough to go in easy. Good luck either way.
69 X11 Z21 L14 glide
o
« Reply #4 on: February 26, 2014, 12:05:42 AM »
  It may be tight possibly from being slightly out-of round. If it looks like it is just a tight friction fit and not an obvious over sized OD, then try putting a thin layer of grease on the flange and using a wooden block across the OD, tap it in.
Again, this is only if it looks like it wants to go in but is just snug. I use grease at times for stubborn exhaust fittings and it works great.
Good luck!
TODD
« Reply #5 on: March 01, 2014, 04:08:31 PM »
What source are you using? The ones at Heartbeat don't list O.D. My D&R 2 1/4" aluminized system didn't come with them, so I have none installed.
Does NAPA source them? I'd like to buy a set and put them in.
« Reply #6 on: March 01, 2014, 04:53:24 PM »
I'd think any good exhaust shop could make those for you...  if they have access to the pipes and exhaust manifolds, or exact measures.
1967RS/SS
« Reply #7 on: March 01, 2014, 06:29:47 PM »
Thanks for all the help fellas! I ended up going to a local auto parts store and finding what I needed there. They need to be trimmed down a little (too long) but other than that they slipped right in.  Two pieces for $5!
1967 RS/SS L-48
Van Nuys 01C
Joseph
