Author Topic: Cowl Tag Check  (Read 32321 times)
vtfb68
Re: Cowl Tag Check
« Reply #15 on: February 19, 2014, 03:49:18 PM »
What about the other body with the TT AND the hidden VIN's?  another questionable car. How many original parts does it take to make a fake?
   VT
68 08E LA RS Y2 749 L30 M35
Re: Cowl Tag Check
« Reply #16 on: February 19, 2014, 03:55:30 PM »
Again, just my opinion, but...
If the VIN tag stays on the original body, and each part replaced is done one at a time and documented with photos at each step, that is probably OK.
Moving the VIN tag from a car to another body is not OK.
I understand that but what if the cowl & dash needed to be replaced and the tag & vin & hidden vins had to be moved to new pieces? Would that not be similar if not the same.  Im not busting your balls just wonder when the gray area ends and the line begins.
Re: Cowl Tag Check
« Reply #17 on: February 19, 2014, 04:55:16 PM »
Just my opinion, but those are not the same, and law enforcement knows the difference.
Panel replacement (and documenting each step) is probably OK and is not the "easy way out".
Moving a VIN tag to a rust free body is a VIN swap.
Mark
Re: Cowl Tag Check
« Reply #18 on: February 19, 2014, 07:13:29 PM »
Moving a vin tag, and sheet metal sections with the hidden vin numbers on it from one car to another body that had a different VIN on it originally is a felony in every state in the union.  Moving a VIN tag, and hidden vins numbers from one car to a replica body like a Dynacorn is OK, as the Dynacorn body is considered a large replacement part, it was never a car before the VINs were transfered to it.  That said, whats a ZL1 VIN tag on a replacement body with a non original engine and drivetrain worth?  don't know but it shouldn't be much higher than 0.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
jdv69z
  • 69 RS Z/28 52E
Re: Cowl Tag Check
« Reply #19 on: February 19, 2014, 08:17:11 PM »
I agree with Mark. If the ZL1 is all about the aluminum 427, and the original motor is gone, I don't feel what's left is all that special. Certainly not 6 figures special. Same with a Z without the 302. To me, it's about what it is, not what it was.
Jimmy V.
VINCE Z28
Re: Cowl Tag Check
« Reply #20 on: February 19, 2014, 08:50:59 PM »
So is a rebody like this ZL1 legal?
Mark
Re: Cowl Tag Check
« Reply #21 on: February 20, 2014, 01:05:03 AM »
Not if the donor body had a VIN number originally, ie it was another 69 Camaro made by GM.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Re: Cowl Tag Check
« Reply #22 on: February 20, 2014, 04:26:37 AM »
Moving a vin tag, and sheet metal sections with the hidden vin numbers on it from one car to another body that had a different VIN on it originally is a felony in every state in the union.  ...
That's correct, because that is one method employed by auto thieves, to hide the VIN of the car they've stolen...
...Moving a VIN tag, and hidden vins numbers from one car to a replica body like a Dynacorn is OK, as the Dynacorn body is considered a large replacement part, it was never a car before the VINs were transfered to it.  ...
This statement would seem to imply that it's not the 'application of a VIN' to a autobody that is illegal, but the actual removal of a VIN from a factory built auto body that is illegal...?   If so, wouldn't it be an illegal act to remove the VIN from the rusted/damaged car *(ZL1)*  in this example case???   Does this suggest that law enforcement authorities could discern that the body the VIN was applied to was a 'dynacorn' rather than a stolen car body (but we can't??)..
... That said, whats a ZL1 VIN tag on a replacement body with a non original engine and drivetrain worth?  don't know but it shouldn't be much higher than 0.
All it says to me is that the person (owner) at one time had possession of a ZL1 body, before he cut it up (assuming the plate were original)...  not much different than holding the registration slip of a ZL1 (or ??) that you bought/owned at one time, but now don't...
Z282NV
Re: Cowl Tag Check
« Reply #23 on: February 02, 2019, 02:40:45 PM »
After selling at BJ this year (2019) it appears the car is again for sale. The story line appears to be more in line with the truth. Has to be the most expensive VIN tag in history.
https://www.cars-on-line.com/gen3-cars/col1/posting/71181
Joe
69 Camaro
Re: Cowl Tag Check
« Reply #24 on: February 02, 2019, 03:07:49 PM »
"In the late 1970's early 80's the car was mated with another 69 Camaro body. "
That's the line that I like...  :)  ..  in my mind, I'm seeing an old cut up ZL1 car, all worn out from it's racing life to that point...  and a nice bodied 6 cylinder Camaro...  in a dark room.  There are some noises during the night, and then.. the next morning... ..
A Shiny new ZL1 emerges!  :)  (Did the mom/pop survive?).. :)
The story goes on to tell of a couple of additional new 'incarnations'... (maybe that car is the 'original 4th generation ZL1'???
PS.  I've got an original '69 Z28/RS which I would allow to MATE with your (female) Camaro, so long as I get my alpha male Z28 back unharmed.. (If it's smiling, that's OK!)..  the fee for this would be... hmmmm.. what's a good fee for a known good stud Z28??  :)
BillOhio
    • photobucket
Re: Cowl Tag Check
« Reply #25 on: February 02, 2019, 03:20:25 PM »
I thought with a Dynacorn body you had to get a vin number from the highway patrol? I have a friend that worked for Ohio patrol I will have to ask him.
So when does this ZL-1 get someone in trouble?
1968 RS 327 4 speed
Re: Cowl Tag Check
« Reply #26 on: February 02, 2019, 03:50:29 PM »
It should get them in financial trouble as soon as they purchase it!!
Re: Cowl Tag Check
« Reply #27 on: February 02, 2019, 11:40:28 PM »
...So when does this ZL-1 get someone in trouble?
As soon as there is any kind of insurance claim and anytime it is sold and it’s known history is not disclosed. Tainted piece that most don’t want to find themselves a part of ‘cause life has enough complications without investing in a hot mess.
