Author Topic: 68 Fuel Gauge  (Read 27843 times)
68ashgoldRS/SS
68 Fuel Gauge
« on: February 11, 2014, 09:59:51 PM »
Troubleshooting a '68 Fuel Gauge... the needle remains stationary at the 3:00 position regardless if battery is connected, switch on or off... suspect that the gauge itself is bad given this scenario.  Anyone agree/disagree?   I would guess that if another issue (sending unit) it would at least move, and be somewhere in the full to empty range?    Thanks in advance for your comments/suggestions.  Ed
Ed Denney from South Jordan Utah
1968 Camaro RS/SS -Restored
1959 Chevrolet Corvette Restomod-Project in progress
1956 Dodge D100 Pickup -Project
1936 US Soldier, Dad -Best Friend
Re: 68 Fuel Gauge
« Reply #1 on: February 11, 2014, 10:52:47 PM »
Make sure the wire off the sending unit is grounded.  If you have a spare sending unit plug it into the rear harness & ground it and see if you can make the gauge work by moving the float.  If it doesnt then its the gauge.
68ashgoldRS/SS
Re: 68 Fuel Gauge
« Reply #2 on: February 12, 2014, 03:19:17 PM »
Thanks Darrell.  I guess I assumed that since the gauge needle is residing way out of the E-F range that is was bad.  Will need to pull the tank I suppose to confirm that....
Re: 68 Fuel Gauge
« Reply #3 on: February 12, 2014, 03:23:44 PM »
If you have another sending unit or an old one just unplug it from from the rear body harness in the trunk and use a jumper wire from the plug and ground the other side of the unit.  Should work if the gauge is working.  Sounds like you might have a ground problem though.
68ashgoldRS/SS
Re: 68 Fuel Gauge
« Reply #4 on: February 24, 2014, 04:04:53 PM »
Thanks Darrell, finally got around to troubleshooting the fuel gauge...  I separated the connector under the trunk lock/latch mechanism, and grounded the tan wire going toward the gauge... sure enough, the needle went ot Empty....  So it appears that I need to pull the tank, recheck the ground, and most likely replace the sending unit...  I should have checked the sending unit prior to installing the tank... shoulda/coulda...
Re: 68 Fuel Gauge
« Reply #5 on: February 24, 2014, 07:24:24 PM »
I bet the ground wire that is on the sending unit is broken.  They are just soldiered onto the lead.
68ashgoldRS/SS
Re: 68 Fuel Gauge
« Reply #6 on: February 24, 2014, 08:41:26 PM »
Just curious.... if it was a broken ground on the sending unit, should I be able to test this by grounding the fuel line tube coming from the sending unit (which I can do without pulling the tank)?  Doesn't it have the same ground potential as the sending unit ground?  I'm trying to remember if the ground is a lug next to that tube on the sending unit.... That would quickly tell me if that connection is bad/broken...
Re: 68 Fuel Gauge
« Reply #7 on: February 24, 2014, 08:58:10 PM »
You are just grounding the unit itself.  So yes that should work as long as the tube is still in good tight contact with the unit.  Obviously I wouldnt leave it that why but to test yes it should work.  In reality you should be able to ground the tank as a whole and it do the same thing.  (Im sure you know this but) I just wouldnt do it with gas vapors floating around.  Make sure you have a fan blowing the flumes away from you.
68ashgoldRS/SS
Re: 68 Fuel Gauge
« Reply #8 on: February 24, 2014, 09:45:08 PM »
Yep... I was thinking that the tank was insulated from the sending unit by the seal, but I guess where it spins onto the tank via the bayonette connection it would be metal to metal...   If that's the case I'm thinking it is probably not a ground wire issue as the tank support straps should be grounded, therefore grounding the tank..  But will give er a whirl and see what happens!  Thanks again Darrel, your help has been great!
Re: 68 Fuel Gauge
« Reply #9 on: February 24, 2014, 11:45:24 PM »
You should have insulators on the straps. & cushions on top of the tank to the floor so I would still check it to make sure..
Re: 68 Fuel Gauge
« Reply #10 on: February 25, 2014, 04:33:59 PM »
No Camaro was ever built with insulator strips between the tank retaining straps and the tank, although all the vendors want you to believe they were.
Re: 68 Fuel Gauge
« Reply #11 on: February 25, 2014, 05:42:38 PM »
I just assumed that he put the rubber between the straps.
68ashgoldRS/SS
Re: 68 Fuel Gauge
« Reply #12 on: February 25, 2014, 06:52:52 PM »
Thanks Fellas,  no luck.... The ground wire is in the correct location according to the AIM, and has a solid ground connection at the terminal and suspect it's good on the sending unit end as I tugged on a bit. I tried alligator clip ground alternatives, and ther circuit is still wide open....   It's got to be the sending unit.  Good to know anyway!  Will get a sending unit on order, and drop the tank when it comes in...  I understand that the 4BBL cars get the larger fuel line tube (3/8") when ordering....    Any sending unit vendors you guys would stay away from, or recommend?  Here's one I found on ebay from Summit Auto that's priced reasonably.... http://www.ebay.com/itm/68-69-Camaro-68-69-70-71-72-Nova-Fuel-Sending-Unit-3-8-CAGT68-1-/221030543751?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1968%7CModel%3ACamaro&hash=item3376727187&vxp=mtr#ht_1653wt_1362
Thanks again, Ed
Re: 68 Fuel Gauge
« Reply #13 on: February 26, 2014, 03:54:46 PM »
ALL V-8's used the 3/8" main fuel line, and L-6's used the 5/16" main fuel line. V-8's with Q-Jets also used a vapor return line.
Re: 68 Fuel Gauge
« Reply #14 on: February 26, 2014, 04:04:49 PM »
Quote
For 1969. 1967 and 1968 didn't use return lines.
