Author Topic: 4053 DZ carburator  (Read 8510 times)
cam69aro
  • 38,000 mile Jerry MacNeish certified z28
4053 DZ carburator
« on: February 07, 2014, 01:02:00 AM »
i read on the internet a few years back ( i know, don`t believe what you read on the net) that DZ carbs were milled out to a true 800 cfm by Chevrolet. i would guess the reason being truth in advertising ? was wondering if that rumor is true ?
Eldon W 1969 z28 Black with born with driveline X77 38,000 miles-sold
2016 z06/z07 Corvette Black
Re: 4053 DZ carburator
« Reply #1 on: February 07, 2014, 01:10:15 AM »
Read THIS, especially footnote number 2.
« Reply #2 on: February 07, 2014, 01:10:33 AM »
I have had a couple of these carbs and have seen no evidence of such. I'll stick my neck out (until proven otherwise) that this is a bunch of "horse hockey". These cars were mass produced, not blueprinted.
« Reply #3 on: February 07, 2014, 01:48:28 AM »
Honestly we are talking about 20 cfm.  When working at Holley; there were/are variances when flowing a carb that will be as much as a couple 100 cfm.  Usually you use the mean of a batch and come to your cfm flow.  USUALLY..  Has there been carbs that have been manufactured that were suppose to a certain cfm and fell short?  Of course, its like any testing batch testing.  All the tolerances that are used (especially back then) if you had a base plate that was at its min tolerance and a venturi  at it max then you will not get optimum flow because you will create turbulence.  When testing you want best case scenerios to get the best results possible.
« Reply #4 on: February 07, 2014, 02:07:03 AM »
 I'd be very surprised if a stock 302 could flow 800CFM when using stock exhaust manifolds.
« Reply #5 on: February 07, 2014, 02:42:23 AM »
Hard to say if they would flow all of 800, but the combination of large valves, small chambers, big cam and the 472 intake could handle quite a bit. One problem that I know mine had (until I swapped it out for a 850 DP) was a noticeable hesitation, almost a bog, due to the small accelerator pump shot off idle. Fix turned out to be swapping the squirters, or drilling them: ultimate would be to use a Reo 50cc pump and cam, which would give enough fuel to get through the flat spot.
I ran the 850 for years - never a problem with loading up, or bog - of course, the 12.5:1 Manley's and the Sig Erson stick I installed in '75 may have stilted the results somewhat. The 302 would rev to near 8000 in stock form; I did this numerous times, until I snapped a stock spring on cylinder 4 (changed it in the parking lot of my dorm). Still have the spring, and no, it didn't drop the valve. Dang lucky -
« Reply #6 on: February 07, 2014, 04:16:59 AM »
And...   it was a tiny percentage indeed of early Z28s that ran the 'stock exhaust manifolds' more than a few days to a week... MANY were swapped out the first or second day of ownership.  I have a 'first day' take off set that I plan to install when the 302 goes back in..
That brings up a question:  What is the best way to preserve such *perfect no pit manifolds* in such a way as to get full points at the Camaro nats in the original classes?  I've used Calyx (temporary solution but looks too black) and Eastwood Stainless Steel paint (in the past on other manifolds, but neither of those give a totally correct 'look' in my view, but is there something better?
cam69aro
« Reply #7 on: February 07, 2014, 04:33:41 AM »
i guess foot note #2 pretty much summed it up, thanks for the heads up on that Ed, that is one of the reasons i joined this site. The reason i asked was my carb had been milled at some point before i got the car. I bought the car with an 850 Holley and single plane intake but the seller had to have it back and gave me the stock carb and intake in return but it is still in need of rebuilding. I brought the carb to a race car driver/engine builder and he noticed the milling right away. He said the shafts that the butterflies went on were milled down. I had read the rumor about that time and thought it was how it should be. Well i guess not, so now it`s time for the carb to go on a visit to Jerry M to get it back to how it should be.  I am running an out of the box 750 cfm Holley for now so i can use the car but want it as it should be. Thanks for the input guys, stay warm. Im freezing here in Minnesota and can`t wait to get my Z out for some summer fun.
Vince
« Reply #8 on: February 07, 2014, 11:23:04 PM »
I read in an article in a car magazine or book that Holley rated the 4053 at 780 cfm and GM rated it at 800 cfm.  It didn't go into any further detail why each company rated the same carb differently.
Azure1969Z/28
« Reply #9 on: February 08, 2014, 05:16:40 AM »
"horse pucky" or "bull pucky" not "horse hockey" :) at least where I'm from
