Author Topic: 69 brake booster with drums  (Read 5091 times)
dkpilot
« on: February 01, 2014, 03:15:58 PM »
Hopefully a quick question.
I have drums all the way around. Looking to add a booster. Will NOT be doing a disk conversion.
I believe I will need a different master cylinder, correct?
How about the proportioning valve?, do I need one, or are those for the disk brakes?
Anything else I need to think about?
rich69rs
  • LF7/M35/Z22/Z87
Re: 69 brake booster with drums
« Reply #1 on: February 02, 2014, 02:44:45 AM »
Drum brake master cylinder for power brakes (p/n 5460465) has dual bleed valves, one for front and one for rear, due to the master cylinder being mounted at an incline when bolted to the booster.  The correct master cylinder (if configured / rebuilt properly) also has RPV's (Residual Pressure Valves - a type of check valve) internally at each connection behind the seats.    The RPV's prevent pressure bleed down back into the master cylinder and keep the shoes properly positioned.  No proportioning valve needed.
Attached link has some good information and used to have some attachments which for some reason are no longer there.
Maybe Kurt or one of the other moderators can address the missing attachments.
http://www.camaros.org/forum/index.php?topic=5983.0
Richard Thomas
1969 RS
KevinW
« Reply #2 on: February 02, 2014, 12:57:39 PM »
The power drum master was not available where I looked.  I just put a repro power disc master and booster in my 4 wheel drum Camaro, without a prop valve, works great!  Did have to reuse one hard line from dist block to rear master due to the fittings being different.
