Author Topic: 67/68 4 speed back up harness Cowl Location  (Read 16766 times)
Re: 67/68 4 speed back up harness Cowl Location
« Reply #15 on: January 30, 2014, 02:17:39 AM »
Chick, will this help, 68 12E Z. Jim
Jim,
That car doesn't have either backup connector hole.   ???
« Reply #16 on: January 30, 2014, 02:18:29 AM »
Your firewall does not have the reverse switch hole for the grommet.   ???  Also hard to tell if you have the holes for the clips for the speedo cable.   ???  Was your car originally a manual trans car?
« Reply #17 on: January 30, 2014, 02:18:51 AM »
Ahhh Paul you beat me to it.  lol
jvb6648
  • 716-796-5263
« Reply #18 on: January 30, 2014, 02:19:18 AM »
oops I think my body guy filled in the hole. About centered and just below the 2 dimples.
68 Z/28
« Reply #19 on: January 30, 2014, 02:21:08 AM »
Yup!   :P
jvb6648
  • 716-796-5263
« Reply #20 on: January 30, 2014, 02:58:30 AM »
Well I hope that answers Chicks question, now I have to redrill some holes, you can see where he plugged them.
68 Z/28
« Reply #21 on: January 30, 2014, 03:44:36 AM »
LOL but not at you Jim but wondering how many of us have had this. This is what I found today! On my build thread Jerry who has a 07C NOR 68Z noted his hole was where Ed's picture showed used by LOS only. Guess what, that is where our hole was.
With Jerry's info I can only assume there were more than a few NOR cars with that hole dimple 3.5 inches below the ground strap hole used to drill out. I'm supplying pictures of the welded hole easily found behind the under dash mat, and after drilling. With the harness installed one can still see remnants of the weld around the grommet. Turned out fine but it took some time. Also reviewed photo gallery and the hole was not there after media blasting which only verifies it was brazed shut in 1983 or 1984 when it was at a friends body shop for paint. No idea why we/he did that but nothing hurt and its fixed.
Used my first finger to rub around the inside weld and thumb to trace the outside on the tape.
Harness installed-
Harness inside & note some weld showing around grommet.
