Author Topic: trim ring fit to rim  (Read 67697 times)
sbmiano
Re: trim ring fit to rim
« Reply #60 on: January 31, 2014, 10:20:13 PM »
Well looks like both will work.  Good thing because I spent 400.00 on these trim rings lol
Its been great to see all the responses and information gathered.  This site is great to be a part of!!!!
69 z28  Van Nuys 04D Legends Certified
09 viper 5k miles
« Reply #61 on: February 01, 2014, 12:03:00 AM »
I'm not so sure both will work!?!? Would be interesting to have at least one person identify that early of a car had those type trim rings. Can you post a picture of what you purchased?
Here are some pics of the trim rings I thought were purchased in 1979 but actually the ship date is Sept. 1980. Invoice has no date, hence the picture of the UPS label. These were purchased for our 68Z.
« Reply #62 on: February 01, 2014, 04:14:08 AM »
Those trims have the correct looking valve stem hole, and the correct looking clips.
How wide is the trim ring, Chick??   My parts book says that trim is only 1-3/4" wide and is for a 6" wide rallye...??
sbmiano
« Reply #63 on: February 01, 2014, 04:04:59 PM »
I should have clarified that both will work at the Nationals as Jerry mentioned.
09 viper 5k miles
« Reply #64 on: February 01, 2014, 07:32:28 PM »
Yes Gary, they are 1 3/4" wide and for the 67/68 DF 15X6 rally wheel. Good eye and why I took the picture that way as I thought later version wheel clips were installed and oriented differently. I always found it interesting that a 67 DC (Corvette) 15X6 was not the same trim ring as the DF 15X6 but the same trim ring as the 69Z wheels......
« Reply #65 on: February 02, 2014, 04:08:19 AM »
The trim rings that were on my '68 Z28 i 1974 when I purchased it were wider than 1-3/4"..  I would have to measure them to see how wide.  They were less width than the '69 trim ring, and the valve stem opening 'opens' all the way to back of the trim ring (ie. like a U shape).   I still have 3 of those trims, so I will take some photos and measurements and post them.
« Reply #66 on: February 02, 2014, 12:39:28 PM »
This is what I thought was an older designed 4 clip and orientation but for sure no expert and not 100% sure. Note how the clip is imbedded in the metal!
rszmjt
« Reply #67 on: June 05, 2014, 07:50:40 PM »
Further to this post,- Today I stripped some original YH wheels dated K-1-9-1-28 YH and there was no evidence of the gouging on the rims that the finger/serrated type trim ring makes.
« Reply #68 on: July 07, 2014, 08:35:36 AM »
I just looked at an original paint, original owner 69 Z. 05A NOR.
Fingers on all wheels, all parts are original and show only finger gouges on the wheel.
Very solid datapoint.
sbmiano
« Reply #69 on: July 21, 2014, 05:00:13 PM »
As I mentioned in previous threads I believe that both at some point where used on the 69 z's.  It is always good to agree to disagree and move on to the next fun subject.  Hope everyone is having a great summer!!!
09 viper 5k miles
