Author Topic: trim ring fit to rim  (Read 67696 times)
rszmjt
Re: trim ring fit to rim
« Reply #15 on: January 25, 2014, 05:44:09 PM »
Picture of trim ring card
« Reply #16 on: January 25, 2014, 07:38:58 PM »
I just learned that they have a reproduction (licensed) copy of that sheet available for around $10...  :)
http://www.ebay.com/itm/1967-1968-1969-CHEVROLET-CORVETTE-WHEEL-TRIM-RING-INSTRUCTIONS-SHEET-CARD-TAG-/140730686674
« Reply #17 on: January 25, 2014, 07:55:09 PM »
I found my 01C X77 in '72, bought it in '73. Trim rings were original to the car as far as I could tell - fingers on all, not 4 clip.
When I parked it on the street at school, I used to pull the rings and derbys, and store in the trunk to keep 'em from getting gone. I got pretty good at pulling them off without a screwdriver/lug wrench, but boy, did they ever scratch up the YH's. 4 clips would have probably been better ?
I am surprised the reason for switching was the 4 clip coming off. They do not pop off all that easy, the finger design come off a lot easier for me. Plus when balancing the wheels you have to make sure the weight doesn't get put on where a clip goes.
« Reply #18 on: January 25, 2014, 08:36:05 PM »
Mine are sort of a PIA to get off ,4 clip design obviously, and original to the car.
Dusk Blue Z
« Reply #19 on: January 25, 2014, 11:48:57 PM »
The printed date on that paper is 9-23-66 and can be found at all the Corvette places. Does anyone have one with a later date like 1969.
1969 Z/28 Legends Certified
1969 Z-10 350 4 speed
rszmjt
« Reply #20 on: January 26, 2014, 05:09:26 AM »
I think Mine is dated 11/68 ?, it is GM original , it was with the car when I bought it in 1974, along with the Pop, battery warranty card, visor sleeve , owners manual, and a lot of other documentation including parts bills etc.
It is not a reproduction and I see no reason to doubt it didn't come with the car.
Dusk Blue Z
« Reply #21 on: January 26, 2014, 05:25:27 PM »
rszmjt,
I was not questioning the originality of your instruction sheet; I was noting the printed date on the ebay listing that 69Z28-RS posted. If there are others that have your date or other later printed sheets, I would say that Chevy did put the 4 clip designs on the early 69 Z/28’s and maybe we could use this information to help track a date change to the second design. Especially if someone has a later sheet showing the internal fingers.
There have been numerous posts about trim rings recently, with different people offering information about what trim rings are on their cars. I will see if I can correlate this information similar to the gas tank codes and post what I find. If anyone else has done this already feel free to post.
« Last Edit: January 26, 2014, 06:27:12 PM by Dusk Blue Z »
« Reply #22 on: January 26, 2014, 08:02:22 PM »
good idea , thanks Mike
sbmiano
« Reply #23 on: January 27, 2014, 05:37:58 PM »
I have the original build sheet and no where does it show what trim rings went on the car unfortunately, and I agree without a doubt that a manual should be issued and sold to the public.  I will tell you that I have received more than 1 answer on numerous parts from different judges at the same show, before they agreed on the correct part.  It is a pretty high expense to transport a car, stay at a hotel, food ect to go to the Nationals so they should design a fact book.  The Camaro Nationals is suppose to be the most prestigious Camaro show in the country and the Legends Judging the most strict so I am all for a book.
At this point I am staying with the finger clips because that is what I was told and I will post the results in June!
69 z28  Van Nuys 04D Legends Certified
09 viper 5k miles
Dusk Blue Z
« Reply #24 on: January 28, 2014, 12:12:25 AM »
My 5A Norwood Z had the original YH wheels in the front and Corvette 8" wheels in the back when I bought it in 1979. The replacement trim rings from GM that I put on the rear in the early 80's were the finger type. I am going to the Legends Judging with the 4 clips. We will have to see how this plays out.
« Reply #25 on: January 28, 2014, 12:33:34 AM »
Please keep us updated on both cars and what the "judges"  say
rszmjt
« Reply #26 on: January 28, 2014, 08:03:26 AM »
Interesting to note my GM Camaro parts book dated Aug/74 shows only 1 trim ring for 1969 Z28 - # 3901708. Then a later issue GM Camaro parts Book dated Sept/75 shows - # 9796696. No trim ring attaching style notes are included in either parts book description.
My GM Chevelle Parts Book dated Apr/76 shows the  # 3901708 trim ring as - 2&1/2" wide -Attaches with 4 clips, fitting 74-76. It then also shows # 9796696 as a supplemented part number for this ring.
Then it shows # 9796696 fitting 70-73 Monte Carlo and it says - Approx 2&1/2" Wide - Attaches with 4 Clips.
I do know that later issue # 9796696 trim rings had the serrated teeth or fingers and were still available from GM I think until approx. 2007? There is also 2 versions of this ring, early issue had Black Serrations and the later issue had Silver Serrations. I have a NOS set of the # 9796696 and the boxes are dated Mar/2000 and they have the silver serrations.
My personal opinion is that the # 3901708 - 4 clip style trim rings were the original line installed trim ring on the Z28, and the later issue # 9796696 trim ring with the serrations was a mid 70,s service trim ring, and was also used by the dealer to replace existing 4 clip trim rings after that part number # 3901708 was superceded to # 9796696.
Jerrys Book only mentions that 2 styles of trim rings were used.  No Offence meant but I honestly don't see how  a legends judge could comment with certainty that in or around Feb 1969 they went to the fingers all the way around the ring to stop the 4 clip design falling off, when the Early dated 1974 GM Camaro and Chevelle parts Book do not show the Serrated type trim ring.
« Reply #27 on: January 28, 2014, 12:57:46 PM »
Your situation might be different than others as it seems you have been "legends certified" and your going back to improve upon your score which I believe in the past they only verify or check the issues that were found wrong during the first go around. Seems to me your in a catch 22 as the easiest would be just change trim rings and bingo you get the points that were deducted the first go around.
« Reply #28 on: January 28, 2014, 03:04:22 PM »
i'm in 100% agreement with rszmjt (and the parts books) on this... as those *documented* facts match my memory as well.
Mark
« Reply #29 on: January 28, 2014, 04:22:08 PM »
Check this out, some of the pictures are missing, but the story is there.
http://www.camaros.net/forums/showthread.php?t=112918&highlight=TRIM+RING
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
