Author Topic: 1969 2-piece Rotor to Hub Bolt Torque  (Read 10696 times)
Z10Mike
« on: January 21, 2014, 03:10:54 PM »
Anyone out there have the torque specs for the bolts that hold the '69 2-piece disc brake rotor to the hub?
Re: 1969 2-piece Rotor to Hub Bolt Torque
« Reply #1 on: January 21, 2014, 03:13:27 PM »
google is your friend (in this day of the internet)... :)
http://www.camaros.net/forums/archive/index.php/t-84329.html
« Reply #2 on: January 21, 2014, 03:25:47 PM »
HERE'S the original thread (a little easier to read), but to boil it all down, 60-65 Ft/Lbs is what you want.
Z10Mike
« Reply #3 on: January 21, 2014, 03:38:34 PM »
Thanks gents for the quick response.   Seems the rotors on these 2-pc units I'm looking to pick up were removed from the hubs long ago and recently turned to about .980 inches with some unknown bolts holding them in place.  I suspected that the combination might have to be turned again after assembly with correct bolts to make them true.  Bolts probably should be at least grade 5 if not grade 8.  I'll have to check my original assembled units for head markings and then buy new bolts and have re-turned.  Further comments/recommendations welcome.
« Reply #4 on: January 21, 2014, 03:41:22 PM »
Here's the original CRG thread on the topic...  http://www.camaros.org/forum/index.php?topic=1812.0
Z10Mike
« Reply #5 on: January 21, 2014, 03:54:00 PM »
Thanks 1968RSZ28 for the link- From that information, it looks like unless these mated hubs/rotors were index marked prior to disassembly, they could be out of balance when assembled again.  Starting to look like more time and trouble than these things are worth. LOL
« Reply #6 on: January 22, 2014, 02:27:25 AM »
You know, it's really not that much different than late-model rotors - only they aren't bolted together, they float on the hubs in most cases. True, they are balanced individually, but when you install a new set of rotors, aren't you really seeing the same chance for imbalance with them changing the balance point of the original set ?
