Kee makes an awfully good top - 32 and 38 oz. fabrics if I remember correctly. Not cheap -
I replaced my Pace top quite a few years ago - the top still looks every bit as good as when it was installed. It does help to use an installer that works with early cars and classics - our local guy came recommended from all sides of the hobby (Corvettes, Mustangs, big cars); top is tight and centered correctly.
Things do change - I bought mine from a well known supplier before they changed ownership - a couple of years ago, I recommended them to a good friend doing a Firebird, with disastrous results (top manufacturer changed, supplier would not credit back as they said there was no problem they could determine). He used my installer, who has done literally hundreds of tops - he said it was the worst top he had seen. Cut wrong and sewn off center.
Be careful in your selection and don't scrimp - worth it in the long run -
