Author Topic: console gauge lights  (Read 5795 times)
Rufcar
« on: January 16, 2014, 10:09:54 PM »
I have installed the gauge tach set and everything works as it should. That said I noticed today that the console gauge lights are on when every the car is running, is that correct? I thought the lights would only be on when you pulled out the light switch?
Everett#2390
  • ^Bess
Re: console gauge lights
« Reply #1 on: January 17, 2014, 12:25:30 AM »
No, OE design has the gray wire attached to INST spade on fuse panel, or tied into radio harness.
I would probably leave well enough alone as the gauges light up when the ign sw is in IGN or ACC.
Not a bad thing, my own personal preference as I wire the 'dash' lights with incoming ign power.
Rufcar
« Reply #2 on: January 17, 2014, 04:52:33 AM »
Thanks for the input, I thought that's where I had it plugged. Ill ck it out tomorrow as I prefer the bulbs on only when dash is on. With the copper line I ran to my oil press gauge its a lot of work to take apart the console to replace bulbs. Tkx jim
Rufcar
« Reply #3 on: January 17, 2014, 08:55:02 PM »
Everett. I pulled the grey wire plug moved it and now all is right with the world!~ Tkx Jim
« Reply #4 on: January 23, 2014, 07:24:47 PM »
With the copper line I ran to my oil press gauge....
Yikes. We lost one test car when it burned to the ground due to a copper line - could still see the marks on the highway for years later. Melted the wheels off of it.
I personally almost burned up a test car that had a copper oil line.
I'd never use a copper oil or fuel line.....
« Reply #5 on: January 25, 2014, 05:48:03 PM »
Correct!  Copper tubing work-hardens with vibration, then fatigue-cracks and fails (and it's used in a lot of aftermarket kits); that's why GM used copper-PLATED steel oil pressure lines before they changed to nylon - they look like copper, but they're steel.
