Roy, I'm assuming this info is on microfiche like the GM of Canada shippers, but did GM give the microfiche sheets to the NCRS or do you have to contact someone at the Herritage Center for the info when you get a request?
Ed, It gets very complicated and long to explain, yes the information is on microfiche. The problem is it is all Chevrolet production, there is 1926 Chevrolet roadster stuff on one page I looked at. so we have 22 cars per page on the microfiche. That's 22 Chevrolets not 22 69 Norwood Camaros. imagine now Chevrolet complete production history. we are talking 100,000's pages of microfiche maybe Millions of pages. We contracted with an outside service to scan these pages and digitize them so we could create a searchable file by VIN. These records ultimately were filtered so that we just have the Camaro, Chevelle, and Nova production plant records. The initial retrieval some three years ago was just the Corvette plant, with that we still got light duty, medium duty trucks, Corvair Greenbriers, and Biscayne station wagons because they were all built in St Louis, I digress. This time through the process we refined the scanning process and just pulled 65-72 Camaro, Chevelle and Nova records. Its a huge undertaking, time consuming and expensive. the problem becomes a damaged microfiche record may not scan well, some pages are missing there will be holes in the records, etc. the end result is NCRS ends up with Searchable DVD's for year groupings and the groupings are not 1st gen second gen they are when one DVD is full we start a second. so 67-68 Camaro are together and 69 -70- Camaro are together. this is not the same page you see from Canada because when we search a Canadian car all we will have depending on the year is something like zone 21 dealer 000, we know that means Canadian export, if you contact Canada with the vin you will get the stuff you guys are use to seeing from Canada.
The records contain only what I have indicated they contained in previous posts nothing more nothing less, for what will become obvious reasons as we progress into these services the only thing that will be supplied out of these records in the service is the official production date, GM zone and GM dealer. we then take that information and search the GM dealer directories for the time frame to determine the dealer name, city and state.
Long explanation to answer your question by saying yes its similar but no its not the same.
