Guys you will get exactly what the above report shows. The Shipping Data Records do contain the wholesale invoice number, order number and indent number. these numbers are not released with this information and will not be provided from this information. The reason for that will become obvious at some point, but we do know at this point that some plants, some years one or more of those three numbers may be located on your cowl tag, or window sticker, or wholesale invoice, or car shipper, or build sheet, or MSO, etc. For that reason the numbers will not be released, they would only serve to assist the counterfeiters. Because of the way the three strings were created at original order conception they are unpredictable and unpublished but great tools for ferreting out in some cases bogus items such as build sheets, window stickers, cowl tags, MSO, etc.
I should add for 68 Ragtop - one of these numbers may or may not appear on the cowl tag and it may or may not always be in the body number location, more research is needed before we make a flat statement such as your "BTW the wholesale invoice # and body # may be one in the same"
