Author Topic: X Codes  (Read 16206 times)
Mark
Re: X Codes
« Reply #15 on: October 28, 2006, 11:51:04 AM »
If the car was made after 1/1/69 and has 2 fuel lines, its an SS.  The only small block that used two fuel lines after that date was the L48.  Both the L34 and L35 big blocks also used two fuel lines, all others had a single 3/8" fuel line.
SS's also required front discs, multileaf rear springs and for the most part a 12 bolt axle, although an L48 with a powerglide transmission would come with a 10 bolt axle.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Re: X Codes
« Reply #16 on: November 02, 2006, 04:37:40 AM »
I'll ask the same questions I asked above:
How many fuel lines and what's the axle code (see sketch under Decoding)?
What's the VIN?
