Author Topic: Info about my 68 camaro  (Read 20630 times)
Matt f
Re: Info about my 68 camaro
« Reply #15 on: January 18, 2014, 03:06:41 AM »
Hey
The build date is 07A
« Reply #16 on: January 18, 2014, 03:11:09 AM »
You're getting a little closer to knowing exactly what you have...  :)    VIN.... L346855    is a July '68 production car..
C130 if It makes any sense     (13 March 1970 cast engine block, assembled 24 March 1970; installed originally in a '70 Corvette with 350ci/300hp/4sp)
the Rear axle ID is BU0925G2 E       (3.73:1 Posi 12 bolt - could be from a '68 or 69 Camaro.. assembled 25 Sept)
4-speed muncie ID P0510
Does the engine pad have a VIN on it?   mmSnnnnnnn   or ??
Matt f
« Reply #17 on: January 18, 2014, 03:15:25 AM »
yes
70s408936
« Reply #18 on: January 18, 2014, 04:44:00 AM »
yes
70s408936
That further confirms the 350/300 engine as being from the 1970 Corvette having VIN partial of 70S408936.
Matt f
« Reply #19 on: January 18, 2014, 07:29:32 AM »
Ok well that solves that!
How do I know what kind of Muncie it is
Knowing that Its a Muncie 4 speed M??
This is great well done lads thanks for any asistance
« Reply #20 on: January 18, 2014, 12:48:05 PM »
Read thru the Muncie information on the CRG...    http://www.camaros.org/trans.shtml#Shifters
Matt f
« Reply #21 on: January 19, 2014, 11:06:51 AM »
Ok thanks.
I've noticed that there are various different packages of brakes offered with the Camaros but y have some got different size boosters and master cylinders
x77-69z28
« Reply #22 on: January 19, 2014, 04:41:27 PM »
GM only made one size booster. You are probably looking at modified cars wit later model 4 wheel discs.
Matt f
« Reply #23 on: January 20, 2014, 12:39:06 AM »
The reason y I ask is I've noticed my 68 has a slimmer master cylinder an only 1 metal strap where as others have a slightly fatter master cylinder and two hook over straps tying in the cover just a quiery
« Reply #24 on: January 20, 2014, 04:52:14 PM »
Read this:
http://www.camaros.org/suspen.shtml#Brakecomp
Matt f
« Reply #25 on: January 21, 2014, 07:13:55 AM »
K so according to that photo of the booster and the master cyl also what was said I have power assisted drums
is that correct? (refer picture attached)
Also the multi leaf springs there are 5 of them, the only time they talk 5 is for a Z-28?
« Reply #26 on: January 21, 2014, 12:57:38 PM »
5 is the normal for multi leaf.
Z = 4
