Author Topic: window washer questions  (Read 8992 times)
Rufcar
« on: December 23, 2013, 03:29:36 AM »
I have no washer parts on my car but when I painted it I did install the correct nozzles. That said I presume the pump goes on top of the wiper motor? I have seen the 69 washer bottles on either side of the engine, which side is correct? I believe my power plug is still there which is rare for this car as most plugs for many things were removed as you can see buy all my other posts last week.
 I have an parts order ready for Ground Up for the a.m. I assume there pump items are semi correct?
I did find a NOS pump on ebay so I know thats USA made anyway.
Re: window washer questions
« Reply #1 on: December 23, 2013, 04:12:33 AM »
.... I have seen the 69 washer bottles on either side of the engine, which side is correct? ....
I believe the washer bottle if on different sides of the engine bay, depending on it RS or not...  RS on passenger fenderwell...  someone will correct me or clarify if it's more to this than what I've said. and there probably is. :)
Rufcar
« Reply #2 on: December 23, 2013, 12:29:45 PM »
Can someone show me a pic of the pump on the wiper motor? I dont seem to have that in my AM I only have a dwaring of the headlight washer arrangement. Is the pump screwed to the weper motor?
« Reply #3 on: December 23, 2013, 01:07:23 PM »
As mounted on the firewall....  and a couple of shots on the bench..
I hope these help.
Rufcar
« Reply #4 on: December 23, 2013, 09:08:56 PM »
Perfect pics thanks.
Rufcar
« Reply #5 on: December 26, 2013, 10:56:26 PM »
Today I installed the washer pump, hoses and bottle and all worked. Yea! The question is what is the wire on the right side of the wiper pump with the rubber cap end? I believe its a blue wire.][URL=http://s196.photobucket.com/user/rufcar/media/washerpumpsmallerpic.jpg.html][/url]
« Reply #6 on: December 26, 2013, 11:40:48 PM »
I think that goes to the oil pressure sending unit behind the back of the manifold.
Rufcar
« Reply #7 on: December 27, 2013, 03:07:40 AM »
68Z I think you might be right as mine was already a tube type pressure unit before I copper plumbed it to my new console gauge!  Thanks
« Reply #8 on: December 27, 2013, 04:56:29 PM »
Did I miss something ? Is this an RS or open headlight car ? I assume open headlight as the headlight washer is not on your unit -
Rufcar
« Reply #9 on: December 27, 2013, 10:04:20 PM »
Steve, Open headlight car.
« Reply #10 on: December 28, 2013, 12:00:05 AM »
Thanks - just curious.
sbmiano
« Reply #11 on: December 29, 2013, 07:03:14 PM »
If this is an open headlight the nozzles should point out.  the rs nozzles
 were pointed to the driver side.  I believe that to be correct
69 z28  Van Nuys 04D Legends Certified
09 viper 5k miles
