Author Topic: 69 Camaro Suspension Question  (Read 3040 times)
TX-302
« on: December 20, 2013, 09:54:16 PM »
My Z has the original springs  which are beginning to sag just a bit on the rear drivers side.  Can someone recommend a vendor where I can get the  front coil and rear leaf springs  that will produce the proper ride height. Thanks
69 Z
BillOhio
    • photobucket
Re: 69 Camaro Suspension Question
« Reply #1 on: December 21, 2013, 12:00:04 AM »
On rear it depends if you want exact look or not. I used a set of correct looking ones from Camaro specialties. For the front look up pozzi racings site or there should be discussion on here about them. I used the Moog 6308. There is one slightly stiffer for a z that might be better on an rs car. Z sits a little lower than a small block car so make sure you get the right ones. I learned after ordering the small block springs from hbc after they said that's what everyone uses. Car looked like motor was out
1968 RS 327 4 speed
