Author Topic: Fill & Drain Plugs 1969 Muncie M22  (Read 21527 times)
Edgemontvillage
« on: December 17, 2013, 06:58:28 PM »
I discovered (with help from Jerry M) that the drain and fill plugs in my 3/69 build date Muncie M22 transmission were likely from either a late 1969 or post 1969 production M22. The plugs are made by Lisle and I have seen them stamped with a P, W (with underline), the Lisle script only, with the Lisle Magnetic 2 script and Lisle Magnetic 3 script.  The Lisle Magnetic 2 design is correct for my transmission build date and most early/mid 1969 and prior M22 production transmissions. The Lisle Magnetic 2 plugs also have a unique dual spade magnet design (see "bottom view" photo).
My M22, "before" photo, Lisle Plugs with P stamping
Lisle Magnetic 2 script plugs, top view
Lisle Magnetic 2 script plugs, bottom view
The installed "after" photos: Lisle Magnetic 2 script plugs
"Other" Lisle transmission plugs I have seen:
Typical of magnetic bottom design of most Lisle plugs I have seen.
copo
Re: Fill & Drain Plugs 1969 Muncie M22
« Reply #1 on: December 17, 2013, 07:59:17 PM »
Did Jerry M say that m-22 the used a magnetic fill plug ? My original m-22 only had a magnetic plug on the drain and the fill plug was non magnetic.
Hans L
« Reply #2 on: December 17, 2013, 10:48:45 PM »
Looks good Lloyd.  Those are correct per my discussion with Jerry as well.   Here's the plugs that are on my Z's original M22.   After Jerry rebuilt it, he requested follow-up pics for his files and research.   Confirmed original for the car/trans.  Built date of the car is 04B.   Note that the trans came with two magnetic plugs - both the same.
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Edgemontvillage
« Reply #3 on: December 18, 2013, 12:30:27 AM »
Thanks for the confirmation Hans, your Lisle plugs look identical to my replacements.
69Z28freak
« Reply #4 on: December 18, 2013, 05:53:46 AM »
Nice work on documenting the different plugs Lloyd. I was unaware until now that the M22 had a drain plug. Great detail here, keep up the good work.
Mike 1969 Grandma Camaro
« Reply #5 on: December 18, 2013, 04:49:44 PM »
All M22's had a drain plug. The cast boss for it was on all Muncie cases, but it was only drilled/tapped for a plug on M22's and on ALL Muncies starting in 1970. Many rebuilders also added the drain plug to pre-1970 Muncies.
« Reply #6 on: December 19, 2013, 12:53:47 AM »
I have visited the Lisle Manufacturing plant that made the original plugs.  I tried to see if they could make them again with the same original lettering.  No dice.
I believe the LISLE 3 plug was in use prior to the M22 being introduced (so it is prior to 1965).
There are at least three minor variations of the LISLE MAGNETIC 2 plug.  The 1969 model year type plugs were also used in 1968 M22s in Camaros.
From what I can tell, the P and LISLE plugs are 1970 and later.  Possibly some in very late 1969 but not sure on that.  Typically used when there was both a fill and drain plug.
The W plug with underline is a fill plug, the normal plug for M20 and M21 transmissions 1969 and earlier.
Edgemontvillage
« Reply #7 on: December 19, 2013, 12:58:42 AM »
Bryon, thanks for filling in some additional details on the applications.
« Last Edit: December 19, 2013, 01:01:34 AM by bcmiller »
« Reply #8 on: December 19, 2013, 01:02:58 AM »
Lloyd, I changed your quote from my earlier post because I made some edits after you made the quote.
Your second picture shows two types of the LISLE MAGNETIC 2 plug.  I will try to post a picture of the other one later.
« Reply #9 on: December 19, 2013, 01:28:19 AM »
Well I guess there are maybe four different LISLE MAGNETIC 2 plugs.  And the 3 plug is a larger diameter.
Plug with the 2 in the lower left is probably a 1965-1967 M22 plug.
« Last Edit: December 19, 2013, 01:59:41 AM by bcmiller »
« Reply #10 on: December 19, 2013, 05:50:13 PM »
Another picture showing plugs from both sides.  From left to right.
LISLE MAGNETIC 2
LISLE magnetic
P magnetic
W fill plug (note - not magnetic)
No marks magnetic - current plug that is not correct, but is functional for the task.  I have about 100 of these new.
Edgemontvillage
« Reply #11 on: December 19, 2013, 08:50:25 PM »
LISLE MAGNETIC 2
LISLE magnetic
P magnetic
Quite the collection Bryon.
69Z28freak
« Reply #12 on: December 19, 2013, 08:54:58 PM »
LISLE MAGNETIC 2
LISLE magnetic
P magnetic
Impressive!
rodent
« Reply #13 on: March 06, 2016, 07:24:40 AM »
I have one to give away, how do you work out who you give it to????
Not sure if it's for a '69 though  :-\
« Reply #14 on: March 07, 2016, 03:46:52 AM »
Come up with a contest of some sort..  those are fun..  :)
