Author Topic: 1968 Camaro rear spoiler part # (short spoiler)  (Read 18178 times)
jdv69z
  • 69 RS Z/28 52E
Re: 1968 Camaro rear spoiler part # (short spoiler)
« Reply #15 on: December 03, 2013, 02:47:12 PM »
I went as far as checkout on that site. Shipping was like $145.00?? Stopped me in my tracks!
Jimmy V.
« Reply #16 on: December 03, 2013, 03:35:38 PM »
Yes, GMPartsDirect has cheap prices on their parts, but they make it up on the "shipping and handling"!!
Or, you can go the EBAY ROUTE and pay $375 and no shipping.
Mark
« Reply #17 on: December 03, 2013, 03:46:54 PM »
by 'hardware'..  I assume you mean the washer/rubber/nuts?   but the studs ARE installed in the spoiler from the factory?
Are you talking about a hunk of 1/4"-20 threaded rod, or the original double ended studs with a lag thread on one end, and 1/4-20 on the other with the integral step between them.  The ones I've seen have threaded rod only.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #18 on: December 03, 2013, 04:43:24 PM »
I don't really know what was installed in the '68 spoilers, but I'm familiar with what is in my '69 .. which is a double ended stud, with a wide flat flange in the middle (which serves as a stop when the stud is screwed into the fiberglass spoiler, and serves to prevent the fiberglass from being busted out by too much torque.).  The following photos are from my factory original rear spoiler studs and retainers (late 09C car).
1) first photo shows both  a rear (short), and front (long) stud as used on the rear spoiler (there are 4 of each, and the long ones *may* come be installed in two differing lengths, with the longer ones used on the center two locations).
2) Second photo shows the two different retainers (nuts with encapsulated washers).  The nut with the wider washer also included a 'rubber washer' which served as a seal to prevent water from entering the trunk around the stud - the rear most studs were located behind the trunk area).
3) Third photo is of one of the longer studs after removal from a spoiler.  It isn't very visible in this photo, but this stud has a wide thin flange 'stop' between the two threaded sections).
MyRed67
  • SZZLN 67
« Reply #19 on: December 04, 2013, 05:13:22 AM »
 Yes, hardware is just the nuts.  You need to install the "Gum/Caulk" yourself the kit I purchased didn't include it, but I had a whole box of it for putting car back together.  BTW, still have some leftover.  And, Yes, the studs are installed at the factory.  I was lucky enough to purchase a NOS #3916633 years ago when I knew I wanted one on the car.  You guys will probably "freak" when I share what I paid for mine back in '92,  $89,  I had a friend behind the parts counter at my local Chevy dealer.
« Last Edit: December 04, 2013, 06:00:34 AM by MyRed67 »
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
rare396bronze
« Reply #20 on: December 04, 2013, 05:38:31 AM »
I work in gm part's  put number on gm locator monday Gm say's is disco so don't try gm dealers because we can't order it!
