Poll
What 4 speed transmission and rear axle ratio came from the factory in your 1969 Z/28?
M20 with std 3.73 rear axle ratio
9 (24.3%)
M21 with std 3.73 rear axle ratio
11 (29.7%)
M22 with std 3.73 rear axle ratio
2 (5.4%)
M20 with economy 3.55 rear axle ratio
0 (0%)
M21 with economy 3.55 rear axle ratio
1 (2.7%)
M22 with economy 3.55 rear axle ratio
0 (0%)
M20 with performance 4.10 rear axle ratio
2 (5.4%)
M21 with performance 4.10 rear axle ratio
11 (29.7%)
M22 with performance 4.10 rear axle ratio
1 (2.7%)
M20 with special rear axle ratio
0 (0%)
M21 with special rear axle ratio
0 (0%)
M22 with special rear axle ratio
0 (0%)
Total Members Voted: 37
Author Topic: 1969 Camaro Z/28 Original Transmission and Axle ratio combination  (Read 11500 times)
68 Ragtop
If you have or had an original 1969 Z/28 and know the transmission type and axle ratio please answer.
The 3.73:1 rear axle was the ratio you got unless something else was checked on the order form.
The other axle options were economy, performance, and special where you specified in the ratio.
DavidS
  • z28.net
    • www.z28.net
Re: 1969 Camaro Z/28 Original Transmission and Axle ratio combination
« Reply #1 on: November 28, 2013, 04:01:35 AM »
BE or BV or QY is 4.10 ratio.
I voted "4.11 rear" since it's the closest one, and I have a BV code with a M21.
« Reply #2 on: November 28, 2013, 07:44:46 AM »
Not interested in open or posi rear?
68 Ragtop
« Reply #3 on: November 28, 2013, 08:39:01 PM »
Not quite sure what you mean. 4.11 is not an option from the factory or in the poll.
68 Ragtop
« Reply #4 on: November 28, 2013, 08:50:52 PM »
Not for this purpose. I suspect the percentage of posi units is high due to Chevy recommending it with the 3.73 and requiring it with the 4.10 and above.
DavidS
  • z28.net
    • www.z28.net
« Reply #7 on: November 29, 2013, 03:31:32 PM »
I fixed it. Sorry for the confusion.
68 Ragtop
« Reply #8 on: November 29, 2013, 07:09:31 PM »
Thanks Kurt. I forget sometimes there is a small difference between 10 and 12 bolt ratios like 3.08/3.07 and 4.11/4.10.
BTW if you have a special ratio feel free to post it. The poll would get way to complicated if I tried to include all possibilities.
