Author Topic: Fuel Pump Stampings  (Read 12495 times)
Fuel Pump Stampings
« on: November 26, 2013, 01:46:12 PM »
I tried to raise an old thread from the dead ( :o ) but its not showing up as an active topic.
Has the fuel pump stampings been decoded?
Steve Shauger
    • Vintage Certification
Re: Fuel Pump Stampings
« Reply #1 on: November 26, 2013, 08:04:42 PM »
Yes, for example JI40727 decodes to Oct of 69  J=10 I =9 and the application is L78. The second letter is the year G= 67 H=68 . Can post more examples if needed. in 71 the coding changed to include day instead of month. Let me know if you need more info...
Steve Shauger
« Reply #2 on: November 26, 2013, 08:11:04 PM »
so what is the application code for the Z28?  :)
jdv69z
  • 69 RS Z/28 52E
« Reply #3 on: November 26, 2013, 08:19:18 PM »
Here's a pic of my Oct 68 Z fuel pump
Jimmy V.
Steve Shauger
« Reply #4 on: November 26, 2013, 08:59:06 PM »
For 69 40669
Steve Shauger
Steve Shauger
« Reply #5 on: November 26, 2013, 09:01:11 PM »
For 69 40669
Note the HH= Built Aug of 68
Steve Shauger
MyRed67
  • SZZLN 67
« Reply #6 on: November 27, 2013, 12:22:15 AM »
So just the first 2 letters is the Date Code,  the 40669 is the part #?
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
« Reply #7 on: November 27, 2013, 12:31:08 AM »
Sorry to be dense.. *L*...  I could have figured that one out, even under anesthetic...  :)
I think I need one stamped 'HI 40669'..    Could one of you fellas with a pile of those in a box somewhere give me a buzz? *G*
MyRed67
  • SZZLN 67
« Reply #8 on: November 27, 2013, 06:29:01 AM »
OK,,, I've pretty much figured out that this is not the original on my '67  327 engine.  I have this  280N40503  AC Delco pump.  I've seen a couple places that offer this 40503 pump as a repop. pump for the 40727 and 40470.  How does that date code read out?
1967 Camaro  LOS  11A
« Reply #9 on: November 27, 2013, 03:58:40 PM »
Dang.. Did I screw up that again?    What is Aug or Sept 1969?    Hi and II ??   :)
Steve Shauger
« Reply #10 on: November 27, 2013, 06:01:41 PM »
I'm going to say 280th day of 1974. I noted previously in 71ish they started using the day instead of the month. Now could it be 1985? There are other things to look for to determine age, such as size of the AC and the weep hole configuration.
Steve Shauger
BillOhio
    • photobucket
« Reply #11 on: December 02, 2013, 03:48:36 AM »
I have been watching  for one for my z. Hbc had rebuilt ones back ordered but they didn't seem to get any. Anyone have a pile of them and I thought Arthur Gould could rebuild them?
1968 RS 327 4 speed
Steve Shauger
« Reply #12 on: December 03, 2013, 07:49:56 PM »
The last one I had rebuilt was done by Goat Hill for my 69 L34, it was a 40568. I had that done five years ago...
Steve Shauger
BillOhio
    • photobucket
« Reply #13 on: December 05, 2013, 01:49:15 AM »
The 140 cam was put in mine about 71 and they must have changed the fuel pump. Mine is now a 234k42080. The crank was balanced and bearings were dated fall 71
1968 RS 327 4 speed
MyRed67
  • SZZLN 67
« Reply #14 on: December 05, 2013, 02:49:12 AM »
Yes Steve, it could be 1985, and that probably would make more since as that is about the time the car was rescued out of an Apple orchard.  And the coloring/plating is not all that bad.
1967 Camaro  LOS  11A
