Author Topic: firewall wiring  (Read 4962 times)
69RSZEE28
firewall wiring
« on: November 22, 2013, 06:08:56 AM »
Does the wiring that goes along the firewall through gutter go above or below the washer pump? 1969
Re: firewall wiring
« Reply #1 on: November 22, 2013, 05:40:35 PM »
<<Does the wiring that goes along the firewall through gutter go above or below the washer pump? 1969 >>
That wiring runs above the wiper motor.
69RSZEE28
Re: firewall wiring
« Reply #2 on: November 22, 2013, 06:22:44 PM »
Thanks John, there is a bit of a "valley" on top of the wiper motor that seems should or could have wiring run through it. Wiring that would be run under the washer motor seems would interfere with the accelerator rod.
JJs 67 Camaro
Re: firewall wiring
« Reply #3 on: November 28, 2013, 04:22:29 PM »
I took a lot of photos before I disassembled my 67 for restoration. My wiring rest on the top of the washer motor in front of the washer fluid motor.
