Author Topic: 69 rear brakes  (Read 4573 times)
69RSZEE28
69 rear brakes
« on: November 22, 2013, 05:47:31 AM »
Just wondering if the adjuster on the rear drum brakes should be touching the spring that holds the shoes together?
Re: 69 rear brakes
« Reply #1 on: November 22, 2013, 01:52:22 PM »
Yes
Re: 69 rear brakes
« Reply #2 on: November 24, 2013, 02:10:38 AM »
Gary, a man of many words... :D
j/k (most of the time a paragraph of info)
Yes, but it touches the adjuster just a little bit. There really only 2 ways to install the spring: 1)The wrong way with the spring resting right on top of the adjuster wheel. 2) You want to install it with the larger hook of the spring going over the adjuster wheel, and into the other shoe. And then the metal bracket ( the one with the white ink stamp in the picture) rests against the adjuster and provides a little tension, so when you get the drum on and adjust the shoes you hear the clicking of that piece on the wheel (also so it won't back off). Hope this gives you some more insight, or maybe you just needed the "yes" from Gary.
Welcome to the site!
