I am test fitting my kick panel.... to door panel....to rear seat side panel fitment after having had new quarter panels, new door skins, new fenders, and new inner and outer rockers put on my car.........It is a '68 coupe with the deluxe interior.
I am having an interference problem with the lower half of my door panels and my kick panels binding when the doors are closed.
Maybe I should have done this before all the final panel fitting was done on the side of the body but the quarter panels, doors, and fenders have all been fitted to each other and there is no going back on that now. This is a probem I didn't see coming.
The interior hasn't been in this car since 1988 and I have no reference pictures of how all three interior panels fit together as far as gaps or clearences.
The rear side panels are back as far as they will go and the windlaces are pushed tight against the pinchwelds of the quarter panels. The door shells are original to the car and the door panels are located in all their original holes. There is an eighth inch clearance between the top of the door panels and the windlaces. The kick panels are original to the car. I don't have them screwed in but I can't push them back any further.
When I close the doors, the upper half of the door panels slide behind the kick panels but the lower half of the door panels binds against the kick panels, trying to push the kick panels forward. And since the kick panels can't go any further forward, they start to bow.
I am attaching some pictures of how all these panels fit togther. Hopefully somome can tell me what's right or wrong with the way these panels all fit together and a solution on how to improve or fix the binding problem.
Thanks......Dave
