Author Topic: Spare tire hold down bracket location ???  (Read 20594 times)
DAVEN1256
« on: November 11, 2013, 02:09:42 PM »
Does anyone have any reference dimensions to properly locate the spare tire hold down bracket in the trunk?
Re: Spare tire hold down bracket location ???
« Reply #1 on: November 11, 2013, 02:41:49 PM »
Hi Daven,
  Which year and type? (HT vs. Conv)
« Reply #2 on: November 11, 2013, 02:46:54 PM »
Attached are a few photos from my '69 Z28.. original location.  I took these for you with a tape to show you as closely as I could to where it goes.
*(I can't tell  you that all models/yrs were the same because I don't know)..
DAVEN1256
« Reply #3 on: November 12, 2013, 01:53:46 AM »
Thank you for the photos.
My car is a '68 hardtop.....Sorry, I sould have included that.
DAVEN1256
« Reply #4 on: November 12, 2013, 03:07:07 AM »
69Z28-RS.......Thanks again for taking the time to take those pictures. I notice that your bracket is not in the same location as the one in the first picture I provided. That is not my car in that picture and I have no idea if that bracket is in the original location or not.
I wonder if someone could take the dimensions I am showing in this picture were dimension "A" is from the centerline of the bracket to the center of the curve where the trunk floor transitions from the flat part to the sloped part............and dimension "B" is from the centerline of the bracket to the center of the stamped ribs.
It would be interesting to see if the bracket is in the same place on most cars or if this is one of those "it's different on every car" situations.
Thanks......... Dave
« Reply #5 on: November 12, 2013, 03:43:49 AM »
Hi Dave,
   It may be easier than you think to find the correct location. There should be dimples in the floor surrounding the location the jack hold down should be mounted. The posted picture you show looks to be correct for a hardtop though I can't see the dimples due to what looks like seam sealer but the proximity looks close enough if using the floor stamping as a reference.
 Attached is a picture of my 67 4B LOS hardtop, which I think is the same for 68, and the jack hold down is mounted between dimples in the trunk floor. There are other dimples in the area off to the right side but this picture shows the ones that are used for a HT. I couldn't get closer because the car is stored on a lift and I was on the ladder.
  Hope this helps.
DAVEN1256
« Reply #6 on: November 12, 2013, 01:30:02 PM »
Mike, thank you for the picture.
When I visit the body shop where my car is at later today, I will check to see if the dimples are there in the reproduction trunk floor.
« Reply #7 on: November 13, 2013, 02:14:08 AM »
I don't think you will find dimples in the repro floor pan.  The spare hold down bracket is one thing that has to be removed and placed on the repro floor. Happens a lot.....
rod396
« Reply #8 on: September 03, 2015, 08:49:46 PM »
Wow, this sure generated a load of interest!
So, at this point, there is no compelling evidence of the bracket location in a Coupe differing from small/big block(?).
« Reply #9 on: September 04, 2015, 03:36:49 AM »
 I can't see why there would be a difference. Only coupe vs. convert is where the differences are.
The tire pressure decal would be different between the SB and BB.
Boston14
« Reply #10 on: September 04, 2015, 11:01:53 AM »
The other difference in mounting location, (besides coupe and convertible) is if the car has a space saver spare or not.
Boston
boston14
1969 SS/RS 350 Convertible
« Reply #11 on: September 04, 2015, 02:04:39 PM »
Boston
without some form of factual evidence, it's difficult for me to believe that Fisher welded the hold down bracket in a different position based on purchasers' choice of 'spare tire type'.....?   Do we have factual evidence to that ??
« Reply #12 on: September 04, 2015, 09:41:50 PM »
Gary if you look in the 69 AIM RPO N65 sheet A1 it certainly looks different to the wheel position in RPO 10 sheet A2.
Boston14
« Reply #13 on: September 04, 2015, 09:42:57 PM »
My car came with a space saver spare.  As shown on the original Jacking Instructions, the space saver is mounted in a different position from the full spare.
boston14
« Reply #14 on: September 04, 2015, 09:48:46 PM »
Can you take some measurements of where the bracket is welded to the floor?  Like this.
