Author Topic: 69 Z28 passenger exhaust manifold pic  (Read 69965 times)
Re: 69 Z28 passenger exhaust manifold pic
« Reply #60 on: November 19, 2013, 01:56:31 AM »
Wtg Gary. Now if you could go ahead and order it and install it for him....
If you were a good CRG member you could make that happen...j/k
« Reply #61 on: November 19, 2013, 02:22:33 AM »
One can lead a Camaro guy to water, but you cannot make him drink.... :)
69Z28
  • 69 X33D80 Z28
« Reply #62 on: November 19, 2013, 02:53:34 AM »
The local GM dealer here told me discontinued as well.
GaryC
« Reply #63 on: November 19, 2013, 03:46:08 AM »
It sounds like Gary W.(RS) found some old stock , hopefully that inventory is correct and one of the dealers will have it for you Gary. Gary W. did the leg work and found them for you, I look forward to hearing that 1 of the dealerships still had it.
« Reply #64 on: November 19, 2013, 04:41:19 AM »
they both had one as of this morning, and there were other dealers with stock as well.  The Iliinois dealer must have known I was calling LD, as he told me the price was $95.20 plus shipping... (so he was willing to ship to the customer).  I specifically asked for this part number.   They each confirmed they had one by checking their shelf, and they each told me the part was still in the GM box.  SO. If you want it for that price, call them tomorrow morning.. early.. :)
« Reply #65 on: November 20, 2013, 04:39:21 AM »
Just Curious if Gary (or anyone else) called and bought the heat risers today?    $95 is not 'cheap', but it's apparently the list price now for that part, and MUCH cheaper than the $240 on Ebay for the same part...
jdv69z
  • 69 RS Z/28 52E
« Reply #66 on: November 20, 2013, 01:23:45 PM »
Not sure if there is still interest, but here's pics of my 69 Z manifold/heat riser again. I think I have the heat riser in the correct orientation this time.
Jimmy V.
jdv69z
  • 69 RS Z/28 52E
« Reply #67 on: November 20, 2013, 01:25:01 PM »
And more.
Jimmy V.
Charley
« Reply #68 on: November 20, 2013, 03:16:52 PM »
My website has a engine pic of the 70 Z with 1100 miles.  Pic is too large to post here.   http://www.1970z28camaro.com/engine/
« Reply #69 on: November 20, 2013, 03:53:24 PM »
Yours seems to be oriented towards the firewall, Charley..   Are the part numbers for the exhaust manifolds and heat risers the same for '69 and '70 ??
« Reply #70 on: November 20, 2013, 05:20:03 PM »
Mine is oriented the same as Charleys. Now how does it show it is mounted in the 70 AIM?
1968 Z28
« Reply #71 on: November 20, 2013, 11:56:24 PM »
FYI....There are two different searches when you request a part number....normally you give them a part number and they will search to see if they have it in stock or if  it is currently not discontinued, they will order it for you.  There is another search where they will query all the other GM dealers for the part number to see if they have in stock....normally they will not do this for you as it is time consuming and they do not want their parts guys taking up this additional time.  If your are on good terms with a local parts guy, you might get this done for you if you ask.
That has been my experience anyway.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
x77-69z28
« Reply #72 on: November 22, 2013, 04:17:34 PM »
My 70 Z heat riser is positioned the same as Charley's. I wish it was together as Charley's!
69Z28
  • 69 X33D80 Z28
« Reply #73 on: November 23, 2013, 04:53:36 PM »
I'm going to assume that we have this figured out? Seems to me there are 2 ways for this valve to be built and the 2 I have are for different models and year Chevrolets and not used on the Camaro, but I am only guessing there. Thanks for the help in locating the valves, that was nice of you Gary W. to do that not just for me but for others that are looking. I'm going to keep looking for a decent used one and see what I can find. I can use the wrong one at this point until I do find one.
GaryC
MyRed67
  • SZZLN 67
« Reply #74 on: December 05, 2013, 05:22:28 AM »
Maybe this has already been completely resolved.  After doing some checking I believe #3887023 Heat valve was used from '67 to '69 on all Smallblock Camaros.  I am seeing also that it is called for from '64 to '72 on Smallblock Chevelles and Novas.  As for orientation pics. in replies #30,#33, and #45 all seem to be the same, on the outside parallel to the frame, with the heavy "weighted" end of the lever pointing back towards the Firewall.  Jerry McN. also has a Blue unrestored  '67 Z28 on his website that appears to have this same orientation.  Maybe he can chime in, or give him a call.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
