Author Topic: 69 Z28 passenger exhaust manifold pic  (Read 69986 times)
69Z28
  • 69 X33D80 Z28
Re: 69 Z28 passenger exhaust manifold pic
« Reply #15 on: November 11, 2013, 10:02:18 PM »
Does the big block and the small block share the same heat valve? I wonder if I have one for a BB. Huh!?
GaryC
Everett#2390
  • ^Bess
« Reply #16 on: November 11, 2013, 10:21:08 PM »
One '68 327 I had, had the weight parallel to pass frame rail with counterweight to the front.
I would think the valve would be universal fit as it would match manifold ID.
A '64 Impala 327-300HP, ram horn manifold had the weight to the rear of manifold.
x77-69z28
« Reply #17 on: November 11, 2013, 11:13:16 PM »
Gary, my 69 is still running hooker headers, but I just looked at my exhaust manifolds for the 70 Z project. I cut off what was left of the original exhaust. My heat riser has the weight to the outside, parallel with the frame rail. Being 57, I can't post pictures. I can email them to you.
Buddy
69Z28
  • 69 X33D80 Z28
« Reply #18 on: November 12, 2013, 01:18:23 AM »
Buddy
I sent it to you in the PM you sent Buddy. Can we assume the 70's were the same?
GaryC
69Z28
  • 69 X33D80 Z28
« Reply #19 on: November 12, 2013, 01:41:26 AM »
Hey Everett like what's in this pic. LM1 350/255 69 Impala. The one I have in hand and the one I'll be be getting in a few days are exactly like what's in my 69 Impala in this pic.
GaryC
69Z28
  • 69 X33D80 Z28
« Reply #20 on: November 13, 2013, 07:40:53 PM »
OK. Just got the other one in today. Same as the one I already have. Still think both are wrong for the 69 Camaro Z28. Anybody else have a known good heat riser valve for a 69 Z28?
GaryC
VINCE Z28
« Reply #21 on: November 14, 2013, 01:17:39 AM »
Gary there is a NOS one in the box for Z- 28  part number 3887023 on ebay # 190688527946. Very $$$$
69Z28
  • 69 X33D80 Z28
« Reply #22 on: November 14, 2013, 02:01:58 AM »
Compared to this pic the 2 I have are wrong then. Unless other members show a clear view of an original I guess we'll never really know. Can anyone confirm what is correct? So far JohnZ has the best overall view that would be the same as the pic. $240.00...that's a load of change. I paid $5.00 a piece for the ones I have. I'll just keep digging. The right one is bound to pop up.
Anybody have any idea what the cast # 3746844 heat riser goes to?
GaryC
« Reply #23 on: November 14, 2013, 02:10:35 AM »
that NOS one appears to be the same configuration/appearance as the one on JohnZ's car..
jdv69z
  • 69 RS Z/28 52E
« Reply #24 on: November 14, 2013, 03:45:27 PM »
Gary, I have my original 69 Z manifolds on a shelf in my basement. The heat riser is with them. I can take a pics if you want, and forward to you.
Jimmy V.
69Z28
  • 69 X33D80 Z28
« Reply #25 on: November 14, 2013, 06:36:54 PM »
Anything at this point will do. I need to figure out what others have so I can determine if I need to keep looking for the right heat riser of what I have is correct too.
GaryC
x77-69z28
« Reply #26 on: November 14, 2013, 08:14:57 PM »
Gary, something happened to my camera. All pics are coming up blank! It looks like johns z's, but the weight is to the outside parallel to the frame rails
69Z28
  • 69 X33D80 Z28
« Reply #27 on: November 14, 2013, 08:29:54 PM »
That's OK. Is the block on the end of the lever pointing to the front of the car or the firewall? Something I have been wondering about is was the heat riser just installed in any position even at the plant? and was there different ones.
GaryC
1968 Z28
« Reply #28 on: November 15, 2013, 12:36:18 AM »
According to my July 1969 issue of the 1967-1969 Camaro Master Parts catalog, the heat riser valve is the same part number for the 1967 thru 1969, 302ci, 327ci, and 350 ci engines and that part number is #3887023.  I have my original 1968 Z28 heat riser valve in my hand and it looks identical to the NOS one shown above.  I would take a picture of mine but being it looks identical, I see no reason for another picture.
BTW.....the 1969 AIM shows in the exact position as John Z's.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
69Z28
  • 69 X33D80 Z28
« Reply #29 on: November 15, 2013, 12:58:05 AM »
So I wonder then what does the 3746844 go to?
GaryC
