Author Topic: L78/L89 Intake Manifold Gasket  (Read 5257 times)
blackss69
« on: November 03, 2013, 09:01:52 PM »
What is the best intake manifold gasket for a stock L78/L89 that has a blocked heat passage.?  I looked up and maybe Felpro 1211 with stock size ports or Victor Reinz has a nitroseal with the stock size ports.
acelr8
Re: L78/L89 Intake Manifold Gasket
« Reply #1 on: November 04, 2013, 01:53:09 AM »
I use MR gasket 108. Trim the outside with a razor knife when assembled. The 1211 has a larger port openingbthan I like. Jeff
Jerry@CHP
« Reply #2 on: November 09, 2013, 05:38:25 PM »
Paragon Reproductions makes a perfect replacement, GM part #3955527.   This is what we use for the engines we rebuild here at CHP/
Jerry
« Reply #3 on: November 10, 2013, 12:06:53 AM »
Jerry
Same thing for SBC manifold gaskets. I utilize Paragon (Corvette specialist) for many restoration items as they and other Corvette supply houses are in tune with NCRS restoration needs.
