Author Topic: Correct rivets for the ash tray  (Read 6772 times)
scoop
« on: October 31, 2013, 01:47:03 AM »
Does anyone know where to find the correct rivets to rivet the ash tray to the front pull out. I disassembled it to refinish the parts separately and now need to reassemble it with the correct rivets. Any help would be greatly appreciated. I will send it out if there is someplace that will do it to the correct specs.  Thanks,. Scoop
scoop
Re: Correct rivets for the ash tray
« Reply #1 on: November 22, 2013, 01:44:20 AM »
I finally found the correct rivets for the ash tray. I also purchased the tool to mushroom the ends correctly. If anyone needs theirs done send the pieces to me and I will rivet them for you. Pictures of the finished product are attached.  Scoop
« Reply #2 on: November 22, 2013, 02:03:03 AM »
Very nice..   :)
« Reply #3 on: December 01, 2013, 01:23:17 AM »
Can you post a Pic of the tooling?
Jim W
scoop
« Reply #4 on: December 01, 2013, 02:14:21 AM »
Here are some pictures of the tool where it can be purchased. Need anything else let me know.  Thanks, Scoop
« Reply #5 on: December 02, 2013, 01:05:31 AM »
Nice.
Assuming: Semi-Tubular Rivet, 1/8x1/8 In
Good job. Thanks for sharing.
scoop
« Reply #6 on: December 03, 2013, 01:33:50 AM »
Yes   1/8 inch by 1/8 inch semi tubular rivets. They are for rebuilding Tonka Trucks.  Thanks, Scoop
