Author Topic: Antenna - Rear Quarter  (Read 20155 times)
camaroman1969
« on: October 29, 2013, 12:33:00 AM »
Does someone know when factory installed radio antenna on rear quarter panel ??   Thanks!  Don
jvb6648
  • 716-796-5263
Re: Antenna - Rear Quarter
« Reply #1 on: October 29, 2013, 01:01:28 AM »
My 12E '68 came with one.
68 Z/28
camaroman1969
« Reply #2 on: October 29, 2013, 01:03:47 AM »
Jim, What kind of radio is in your car??  AM/FM stereo?? Don
« Reply #3 on: October 29, 2013, 01:08:17 AM »
  My 5E 67 has it. The rear antenna option was available in 1967 and was for AM only. Not sure of 68 or 69 if it was still limited to AM.
« Last Edit: October 29, 2013, 01:33:30 AM by Mike S »
jvb6648
  • 716-796-5263
« Reply #4 on: October 29, 2013, 01:22:54 AM »
AM
68 Z/28
« Reply #5 on: October 29, 2013, 01:35:14 AM »
I know of 2 68's both originally AM radios, both non spoiler cars & one was rear & the other was front..  So I'm not sure there was a standard for non spoiler AM cars...
All spoiler cars were front fender regardless radio
AM/FM were front fender
AM with no spoiler I've seen both ways...
sdkar
« Reply #6 on: October 29, 2013, 03:30:30 AM »
My 68 Camaro convertible with 250c.i. 6 cylinder, with manual steering, manual drum brakes, non-spoiler car had an antenna on the passender rear.
lakeholme
  • 68-12D L30/M35
« Reply #7 on: October 29, 2013, 11:24:10 AM »
When optiion U73 was ordered: antenna, manual, rear mounted, (AM only).
lakeholme
  • 68-12D L30/M35
« Reply #8 on: October 29, 2013, 04:09:56 PM »
The Options PDF is always helpful on those kinds of questions.  Also look at D80 about the spoiler issue.
My 12D 68 does have U73.
Or are we all mistaking your question? Do you mean when it happened in the assembly process?
camaroman1969
« Reply #9 on: October 30, 2013, 12:26:44 AM »
Yes, that my question, When was a rear antenna installed at factory??  When option "U73" was selected?  I would assume.  Thanks
« Reply #10 on: October 31, 2013, 03:19:39 PM »
Obviously, when the order specified U73, the plant installed it; Fisher Body installed the front-to-rear antenna cable in the body, and Chevrolet drilled the hole and installed the antenna base on the rear quarter panel.
adjudimo
« Reply #11 on: November 01, 2013, 08:41:03 AM »
My 03 1967 has U73 and rear antenna on passenger side.
J.R.
miket1
« Reply #12 on: November 02, 2013, 06:49:04 PM »
My Survivor 69 Z28, built 10B, 1968,  has rear antenna, it shows as an option on my original paperwork for $9.50,, has the original AM Radio that works great
69 Z28 Burgandy
« Reply #13 on: November 02, 2013, 07:15:03 PM »
My 68 z ( no spoiler originally from factory ) had it in the rear  build date : 4th week in April.
My68SS
« Reply #14 on: November 16, 2013, 01:37:37 PM »
I can only imagine that they wanted the aerial for am/fm to be front fender mounted, in order to keep the aerial lead as short as possible for least signal loss at fm frequencies.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
