Author Topic: Exhaust 69 camaro  (Read 16258 times)
Jbyer8
Exhaust 69 camaro
« on: October 26, 2013, 11:29:14 PM »
Two questions:
1- What's the best way to get a more aggressive sound out of my pipes? I currently have a SB 350. My buddy has a 67 with 427 and I get jealous... Don't have the money to upgrade to bigger engine so I need best bang for my buck.
2- what are some cost effective things I could do to my 350 to get a little more HP?
77thor
Re: Exhaust 69 camaro
« Reply #1 on: October 26, 2013, 11:34:27 PM »
1- headers; dual exhaust, if you don't already have it... or different mufflers if you do
2- headers, more aggressive cam...
Jbyer8
« Reply #2 on: October 27, 2013, 12:43:12 AM »
What type of headers, cam, and pipes you recommend? Best value.
BillOhio
    • photobucket
« Reply #3 on: October 27, 2013, 01:21:03 PM »
My z had hooker headers on it and exhaust was gone. I am close to Jegs and for about 220 picked up a headers back kit with 2 mufflers. Sounded great and easy to install. All precut. You can search you tube and find where guys recorded exhaust
1968 RS 327 4 speed
Azure1969Z/28
« Reply #4 on: October 27, 2013, 04:04:28 PM »
If you are comparing a high performance BB or SB (11:1, high lift & duration cam) to a typical stock motor of course yours won't sound or perform as good. You can easily over spend on headers and exhaust and it will just sound like a stock motor w/ headers and dual exhaust. louder may not be better.
« Reply #5 on: October 27, 2013, 06:20:11 PM »
Three items are the major contributors to making more power - compression, cylinder heads, and camshaft, matched to each other and your objective. All are expen$ive.
KERR
« Reply #6 on: December 03, 2013, 08:27:58 PM »
you can make a 350 nasty,  just have to open up the pocket book or swipe the visa.
my 67 vette has a 327,  its 60 over, 13.5 compression,  afr heads, ( painted orage) gm real race cam, lunatti ultra light nas car crank,  headman headers into the side pipes..   M22 trans 4:56 gears,  its one nasty nasty little motor,   but it kinda sucks,  $8.00 a gallon fuel, and only one station sale its...
if you looking for that thumpetty thump thump. Thumpety thump thump. sound thats all in the cam..
Kelley W King
« Reply #7 on: December 03, 2013, 09:44:32 PM »
I like Hooker Headers, Flowmaster mufflers, but you need some cam duration to make it thump. Once this is done without a little gear you have a good sounding dog concerning performance. My GTO with the RAM Air cam and 323 gears would not operate in 4th under 40 miles per hour. A set of 390,s and she lit up but it took bucks. Now it takes gas.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
hotrod68
  • almost finished
« Reply #8 on: December 05, 2013, 05:42:36 AM »
  If you just want a nice, mild engine that sounds good my advice is any 1-5/8" headers with turbo mufflers and 2-1/2" duals, a dual-plane manifold like an Edelbrock Performer and a 600 Holley carburetor, and a cam with around 270-280 degrees advertised duration will give it a little thump. Much over .480" lift with stock heads and you'll have valvespring bind problems. This will make a peppy engine that won't break your pocketbook to drive. It won't sound like a 427 simply because it doesn't have the cubic inches, but it'll be fun to drive. Hope this helps.
69CamaroConv
« Reply #9 on: October 24, 2014, 11:56:33 PM »
I used sweet thunder 2 1/2 inch chambered exhaust. Its loud
DEL
« Reply #10 on: December 02, 2014, 05:31:10 AM »
One thing I haven't seen on this thread that you might consider is an X-pipe. The sound is unique and they can be good for a couple to a few HP points. A set of headers, Magnaflows (my personal favorite) and nice mandrel bent pipes and you've got a great exhaust system. There's a tone that the X-Pipe cars make from mid range on up that is addictive.
There are cheaper versions but the workmanship on the Dr. Gas systems is the best I've seen. http://www.drgas.com/
Dave Loney
quarter_miler@hotmail.com
