Author Topic: Correct engine paint suggestions please!  (Read 84713 times)
Re: Correct engine paint suggestions please!
« Reply #45 on: January 26, 2014, 01:03:24 AM »
My daughter just came back from vacationing in Costa Rica last week.
« Reply #46 on: January 26, 2014, 01:39:13 AM »
Kurt,
Make sure you make it to Tortuguero while you're down there.   :)
« Reply #47 on: January 28, 2014, 04:10:16 AM »
Haven't made it to Tortuguero yet. Corcovado is on that list too.
The kid's favorite was up by Cerro de la Muerte, over 9000 feet and cold - they get frost at night this time of year there. A really neat place with big oaks, very different than down lower.
« Reply #48 on: January 28, 2014, 01:07:03 PM »
Kurt,
Might want to see when the best time might be for those turtles.
« Reply #49 on: May 06, 2014, 02:40:11 AM »
Please note that tonowanda built SB had the manifolds installed before painting Flint did not.
What this means is Z28's did NOT come with painted exhaust manifolds.
« Reply #50 on: May 06, 2014, 03:26:43 PM »
<<Please note that tonowanda built SB had the manifolds installed before painting Flint did not.
What this means is Z28's did NOT come with painted exhaust manifolds. >>
That's correct - the process changed at Flint V-8 in 1965 to install the exhaust manifolds after paint; the photo below shows the Tonawanda paint line, and you can see the second engine is a small-block with the exhaust manifolds in place.
« Reply #51 on: May 06, 2014, 07:52:21 PM »
This photo shows what looks to be either a way to manipulate the engine for painting or part of the mask for the end of the water pump and the by pass hose is this correct?
« Reply #52 on: May 06, 2014, 08:46:43 PM »
Sure looks like a mask.  Good eye James..
« Reply #53 on: May 06, 2014, 11:31:34 PM »
It stood out like a sore thumb then again I happen to have been looking at the front of a 396 in paint dress for the last 6 months...
After examining it further I see that the "45 deg rail" looks like it could be covering the Stamp pad...
« Reply #54 on: May 07, 2014, 02:57:02 PM »
Yup, that's correct.
« Reply #55 on: May 07, 2014, 05:55:42 PM »
JohnZ-You mean both? Manipulate engine and/or mask?
« Reply #56 on: May 08, 2014, 04:45:00 PM »
Yup, both.
VINCE Z28
« Reply #57 on: May 08, 2014, 05:40:21 PM »
John how did the guys painting the engines keep for breathing in the paint fumes? It don't look like they had respirators.
« Reply #58 on: May 09, 2014, 05:37:19 PM »
In those days, there was no requirement for personal protective equipment, unless it was requested; most people didn't bother with anything more than a simple mask.
« Reply #59 on: May 09, 2014, 05:42:21 PM »
 Isn't that a water wall in front of them to act as an air filter?
