Author Topic: Brake Bleed tool suggestion ... Motive vs. MityVac ????  (Read 11715 times)
KevinK
    • Hudson Valley Camaro
« on: September 07, 2006, 05:59:17 PM »
...I posted this on Team Camaro, ...but thought to ask here as well.
  Considering Brake Bleed tools, ...what is everyone else using? (if you know the model # of what you are using, ...please post)
 ... I'm looking at two units right now:
A Motive Kit#0250  http://store.summitracing.com/partdetail.asp?part=mvp-0250
...and a Mityvac Silverline Plus #04050.  http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=8309
...I've found better prices other than the links above, ...so the price is within $8 between the two ($70-$80).
I never heard of the Motive before, ...but I am sided towards it since it seems a bit easier to use.
...comments? ...other suggestions?
               Kevin
Re: Brake Bleed tool suggestion ... Motive vs. MityVac ????
« Reply #1 on: September 08, 2006, 06:27:08 PM »
No-brainer - the Motive Products pressure bleeder is the best sixty bucks you'll ever spend; I've fought bleeding stubborn Corvette 4-piston disc brakes for years, and the MP pressure bleeder makes them a piece of cake and a one-person ten-minute job. I've tried all the other stuff (MityVac, Phoenix Injector, etc.) and none of them hold a candle to the MP setup.  :)
KevinK
« Reply #2 on: September 08, 2006, 08:45:03 PM »
...Glad to hear that, ...especially from you John  ;)
     ...I placed an order for the Motive yesterday
            Kevin
hotrod68
  • almost finished
« Reply #3 on: September 09, 2006, 03:46:53 AM »
Low-tech guy here--I lay a cinderblock on the brake pedal and pump it up between cylinder bleeds (chuckle).
jdv69z
  • 69 RS Z/28 52E
« Reply #4 on: September 11, 2006, 07:55:17 PM »
So Kevin, where's the best place to get the Motive Poducts MVP-0250 price wise?
Jimmy V.
Jimmy V.
KevinK
« Reply #5 on: September 12, 2006, 12:02:29 PM »
Jimmy,
   The best price I found, and where I purchased mine was on Ebay as a Buy It Now.
     (using Google's "Froogle" search, ...there are a couple places that are close, ...but tax and shipping add up)
  Here's a link...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300026316609&ssPageName=MERC_VIC_RSII_Pr4_PcY_BIN_Stores_IT&refitem=300022843418&itemcount=4&refwidgetloc=closed_view_item&usedrule1=ItemToItem&usedrule2=StoreCatToStoreCat&refwidgettype=cross_promot_widget
« Last Edit: September 12, 2006, 12:07:52 PM by KevinK »
