Author Topic: 1969 California trim tag code mo 44 ?  (Read 32834 times)
yankeechaser
« on: October 17, 2013, 06:25:01 PM »
has anyone seen this mo 44 before I recall reading something about it once before but not sure any help would be appreciated thank you
Bo
68 07B Z/28 Nor Le Mans w/houndstooth, headrests & gauges
67 03C 4N LOS RS/SS 4 speed plum w/gauges
68 05E Z/28 NOR British Green 714  no tach or console
69Z28
  • 69 X33D80 Z28
Re: 1969 California trim tag code mo 44 ?
« Reply #1 on: October 17, 2013, 07:19:09 PM »
Fixed.
GaryC
« Reply #2 on: October 17, 2013, 07:46:28 PM »
It's not MO44, it's M044.  That's the Fisher Body body scheduling code.  More info here...
http://www.camaros.org/numbers.shtml#CowlTag
yankeechaser
« Reply #3 on: October 17, 2013, 07:53:43 PM »
Thank you both so just a x44 car ? or mo 44 is schedule ?
Bo
69Z28
  • 69 X33D80 Z28
« Reply #4 on: October 17, 2013, 08:13:34 PM »
Not sure how to make that X44 determination on a VN car. Here is something that will better explain the code difference with the Van Nuys trim tag.
http://www.camaros.org/forum/index.php?topic=11013.0
If I'm reading that statement correctly then the M044 is the 13th day of the month (01C, January 3rd week) with the 44th car being built that day? Does this sound correct?
« Last Edit: October 17, 2013, 08:33:40 PM by 69Z28 »
GaryC
HOT3O2
« Reply #5 on: October 17, 2013, 09:11:34 PM »
Since the first day of the month (Jan. 69) was a Wed. would that be part of (12E) or (01A) build? Would you need to know that to determine what day the car was built?
Rick
69 RS/Z28
« Reply #6 on: October 17, 2013, 09:18:57 PM »
No, you can best estimate the exact day your car was built using the VIN, along with the 'end of month' VIN numbers provided in the CRG files, along with the calendar for the month of production, check the number of work days, the total production for the month, and daily production rate, and then calculate which work day your car was 'likely produced (+/- a day)...
UHOH..  I may have spoke too soon, seeing now this was a VN car... ??  Maybe there's a better way for VN???
HOT3O2
« Reply #7 on: October 17, 2013, 09:32:26 PM »
Yes Gary I see what your getting at. I too have VN car. (12B) with a body scheduling code of (I406) and I was figuring a Monday or Tuesday build.
Rick
69 RS/Z28
« Reply #8 on: October 17, 2013, 09:39:34 PM »
I'm unsure if there was an 'uniform' Camaro production schedule at VN...?   Can anyone provide information on that?
69Z28
  • 69 X33D80 Z28
« Reply #9 on: October 17, 2013, 09:54:00 PM »
So this would be I = 9th day of the month January, B week, which is a Thursday, and the 406th car built for that day. Maybe?
GaryC
HOT3O2
« Reply #10 on: October 17, 2013, 10:12:47 PM »
So Saturdays and Sundays don't come into play in this code?
Rick
69 RS/Z28
69Z28
  • 69 X33D80 Z28
« Reply #11 on: October 17, 2013, 10:15:36 PM »
Rick, I'm not sure about VN plant but I thought JohnZ mentioned that Saturdays were common at the NOR plant.
GaryC
HOT3O2
« Reply #12 on: October 17, 2013, 10:22:33 PM »
Well it's a little more clear to me now Gary. At least I can narrow it down to a day or two. It's nice to know when it's your cars birthday.
Rick
69 RS/Z28
69Z28
  • 69 X33D80 Z28
« Reply #13 on: October 17, 2013, 11:00:38 PM »
Rick, of course this is just me thinking this all out in my head and I could be wrong. I'm sure if others are reading this they are calculating too. Seems to me the VN plant can be figured out to the day but the NOR plant is a bit more difficult to pin it down.
GaryC
HOT3O2
« Reply #14 on: October 17, 2013, 11:38:53 PM »
I hear you Gary. I know this isn't scientific but it's nice to all you guys out there to throw this stuff back and forth. And you never know - We might actually figure it out someday.
Rick
69 RS/Z28
