For 69, the grounds are all shared in the taillight housing and the pigtail is screwed to the trunk lock support. But if the lights light up, then not a ground. probably the flasher, there are two, one for hazards (on fuse box), the other is for turn (in a clip on the radio support bar, behind ash tray). Try your hazards, if they work, replace the flasher behind the ash tray.
