Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
69 Z/28 coil bracket
« previous
next »
Print
Pages: [
1
Author
Topic: 69 Z/28 coil bracket (Read 5444 times)
sam
Member
on:
September 06, 2006, 06:25:38 PM »
1969 Z/28 FLAT HOOD car. Does the 298 coil for a flat hood Z/28 use the same coil bracket as the 293 coil? Does the 298 coil bracket lay the coil back a little farther towards the firewall? Thanks, Sam
Tweet
Logged
CRG Member
Re: 69 Z/28 coil bracket
Reply #1 on:
September 06, 2006, 08:49:22 PM »
The coil itself is the same for both applications, but the coil and bracket were received at the plant as an assembly; the one with the laid-back bracket was used with the ZL2 hood, for clearance to the air cleaner base.
Logged
sam
Member
Reply #2 on:
September 07, 2006, 04:39:14 AM »
Thanks John. Sam
Logged
Print
Pages: [
1
« previous
next »
Originality
