Author Topic: What the heck is this?  (Read 9133 times)
69Z28
  • 69 X33D80 Z28
GaryC
ss jim
Re: What the heck is this?
« Reply #1 on: October 07, 2013, 07:56:53 PM »
Gary, I have no idea what that "shield" fits. I have never seen one on a '69 Camaro although anything is possible. I have a factory solenoid heat shield on my '94 Blazer but it does not look like that. It may one of those, " Well it came off of a Camaro." deals.
« Reply #2 on: October 07, 2013, 08:29:57 PM »
I have an idea they may have been fitted to big block cars..... Will have to go and check the AIM.
Petes L48
« Reply #3 on: October 07, 2013, 08:57:46 PM »
That's an auto transmission linkage shield.  I just installed a similar one on a 67 with a powerglide this past weekend.  Gets bolted up along with the bottom flexplate inspection cover on the driver's side.  They may vary a little for T400, between years, etc. See UPC M35/M38/M40 in an AIM for starters  Most got thrown away by backyard mechanics.  Not sure if they're repopped, took me a long time to find the correct one in good condition.
69Z28
  • 69 X33D80 Z28
« Reply #4 on: October 07, 2013, 09:30:58 PM »
Interesting.
GaryC
« Reply #5 on: October 07, 2013, 09:55:15 PM »
That's an auto transmission linkage shield.  ...........  They may vary a little for T400, between years, etc. See UPC M35/M38/M40 in an AIM for starters  Most got thrown away by backyard mechanics.  Not sure if they're repopped, took me a long time to find the correct one in good condition.
  I don't think '67 TH400's used that.
69Z28
  • 69 X33D80 Z28
« Reply #6 on: October 07, 2013, 10:35:12 PM »
Was it strictly Camaro only?
GaryC
« Reply #7 on: October 08, 2013, 05:26:09 PM »
No - other carlines used it too - it was to prevent snowpack/slushpack from jamming up the Powerglide lower kickdown linkage rod and holding the throttle open.
Petes L48
« Reply #8 on: October 08, 2013, 05:32:15 PM »
No, I've seen them on eBay for Impala, Nova, etc.  I think the full size shield was slightly different, not sure about others.
They are shown in the AIM on UPC M35 Sheet A19 for 67, Sheet A20 for 68 and 69.  Don't see them shown under M38 or M40.
67 RS Ragtop
« Reply #9 on: October 08, 2013, 06:29:19 PM »
If I remember correctly, That shield was used only on the early powerglides that had manual kickdown linkages (as per John Z). Not sure if they still used the powerglide with manual linkage rods, etc.. in the '69 model year, would refer to the AIM.  My '67 Camaro with PG has that same shield, FWIW
69Z28
  • 69 X33D80 Z28
« Reply #10 on: October 09, 2013, 02:24:28 AM »
So, if I went to look at the linkage on my survivor 69 Impala LM1 with power glide, that shield should be there?
GaryC
« Reply #11 on: October 09, 2013, 03:03:52 PM »
Yes, it should. For the '69 Camaro, it's shown in section M35, sheet A20 in the A.I.M. All Powerglides had the mechanical rod kickdown linkage.
sdkar
« Reply #12 on: October 09, 2013, 04:29:06 PM »
I hava this on my 69 Pace Car with powerglide.  It fits powerglide only and acts as a shield for the kickdown linkage, which is not a cable like in the TH350, but a set of linkages.  I don't believe you will find this on the TH350 or TH400 cars.
