Has anyone properly adapted a shoulder harness seatbelt from another vehicle into a first gen Camaro?
Can a 2nd gen Camaro seatbelt bolt up to the ceiling (even with a little modification) and the plastic cover used to hide it. Has anyone done this and how does it look?
What about from an entirely different vehicle? Most of the newer cars have the seatbelt (roller/actuator) are mounted on a pillar, and the seatbelt goes up toward the ceiling, wraps around some pulley type arm, then comes down to bolt onto the floor or the side of the seat. Where can we mount the roller so that the pendulum still works properly? I was thinking under the seat, but this throws the angle off and the seatbelt stays locked up.
I do not want to spend the hundreds of dollars for the morris setup when I have access to hundreds of late model vehicles from all the junkyards in my area, and Ican get just about any set for $10. Surely I can make something work. So, has anyone had any success with a particular model or adaptation process?
