No sealer on any original doors I have or had. Sealer may be applied cleanly and minimally, leaving only enough to seal the hem. After paint it would not be detectable. Your use of adhesive would eliminate this step if sqeeze out provided full coverage. Adhesive prevents the usual corrosion. Without it, other hem rust prevention measures are needed. I'd still use cavity wax even with adhesive, just like all cavities.
